LT or LS??? Which engine should go in my SS? - Page 3 - Chevy Impala SS Forum
post #21 of 28 (permalink) Old 01-16-2013, 09:11 PM
jimmyjam's Avatar
Originally Posted by 1FAST94 View Post
Coil packs do not take the opti out of the equation. You do know that, right?
Originally Posted by streetcar2try View Post
Just FYI for the OP, only if using LTCC, it still retain the opti for a signal. If you go 24x, Opti is gone.
right, i had a 24x kit on order before i did my ls swap. luckily they were out of stock and by the time they had them i came to my senses. never even considered the ltcc. its a kludge
However my comment was in regards to and LS engine being less dependable than an LT. its like the local hillbillies down here that say carbs are the best and EFI is junk. i turn into steve buscemi in fargo yelling "I'm not going to debate with you!" its nonsense
1996 Impala SS - DCM - LS swap in progress...
2006 Trailblazer SS - 402ci LS2, RWD 4L80 swap
jimmyjam is offline
post #22 of 28 (permalink) Old 01-16-2013, 10:25 PM
GreenHornet's Avatar
Originally Posted by GA95DCMSS View Post
I know I'm comparing apples to apples in my case, but I'm just saying lol.
My Impala is apples to apples too.
Both are 5.7ltr, t56 cars with 3.73's. with 285 tires out back. ah chit. Ive got 275's out back of the cadi
The cadi will never almost lift the drivers side front on a redline powershift from 1st to 2nd like my SS will.
I know the ls motors are suppose to be so great but I dont see the hype in them over replacing the LT. Unless your going for crazy HP Just build a mean lt1 and enjoy it
96 sob 17,xxx stolen
96 sob t-56'ed 69,xxx totaled
96DGGM DD T-56'ed
05 CTS-V 48,xxx
Issca #2324
T-56,845 cam, JPR f-body heads, 1.6 rr, 58mm tb, SSRI, FLP LT , High flow cats, CIA 3" cat-back, 21" Aerochambers, Dennys DS, 3.73's, Eaton posi, Currie upr & lwr cntrl arms, HA rear bar, F-body front bar, QA1's 6 way frnts, Bilstein 0929 rear, Hotchkis springs, MB OS 17"x 9.5"
[SIGPIC]
GreenHornet is offline
post #23 of 28 (permalink) Old 01-17-2013, 04:15 PM
GA95DCMSS's Avatar
Send a message via Yahoo to GA95DCMSS
Solid Axle vs IRS is probably why...oh and unibody vs body on frame. Just my opinion though. I've seen its pretty hard to cut a decent 60-foot with the cadi, where in the Impala, it's ALOT easier to cut sub 1.7s. Again another one of those my opinion things lol.
Quentin-1995 Impala SS-. New PB coming soon
GA95DCMSS is offline
post #24 of 28 (permalink) Old 01-17-2013, 04:44 PM
I know what your saying GA95DCMSS Im kinda scared to shatter the irs diff, so i dont abuse first all that much.
I love both cars for different reasons. Ive seen you on the other forums. Im Shadowstalker on cadiforums and tpagreenhornet on ls1tech.
maybe ill hit you up for that fast intake if i ever send my heads out to tea.
post #25 of 28 (permalink) Old 02-11-2013, 07:48 PM
Beertestr's Avatar
Re: LT or LS??? Which engine should go in my SS?
Originally Posted by MUSBEJB View Post
Cool. Thanks. I know buying an LS engine is already expensive and THEN doing mods. And they aren't as dependable as the good ole LT1.
You are so sadly mistaken.
Sorry.
Sent from my DROID BIONIC using AutoGuide.Com Free App
Michael -1979 Caprice LS1 - e.t.... recomputing
KDS-Performance.com
Beertestr is offline
post #26 of 28 (permalink) Old 02-11-2013, 08:14 PM
The Bolt-On Terror's Avatar
Unless you're very resourceful like the BEERTESTR, then yes, a conversion is your most expensive route to horsepower.
Dependability....well again that all depends on how well the conversion is done. On average, leaving it as close to factory as possible is going to work out best for you.
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #27 of 28 (permalink) Old 02-11-2013, 09:17 PM
Beertestr's Avatar
Hey, who you callin'..
I just think that if you are going to start pouring money into making power , start with the better design. If all you are looking at is to get to 350/350 hp/torque you can certainly get there cheaper with the LT1.
What about 400/400? What about 450HP? I'm making well over that with a smaller cam than an equivalent(ish) LT4 hot cam in my iron 6.0. On carburetor. What about 500hp and 7000rpm? What kind of aftermarket parts do you have to start throwing at an LT1 to get there?
Lets start this way. Given similar displacements, which engine family makes more stock hp/cubic inch. Stock 5.7L lt1-260 hp.. I'll tikt the scales and say stock LT1 corvette even though it starts at aluminum heads and say 300 hp is the lt1 baseline. LS1 345 HP. Toss a stock cam and better heads on both. Make your LT1 an LT4. 330,HP. Stock heads and cam and LS1 and make it an LS6. It's just heads cam and intake like the LT1-4... but the LS6 makes 405HP.
Stronger block, better oil pump, less leak prone seals, better valve angle, better valvetrain parts, stronger crank, better rods, taller deck, better intake, better ecm/pcm.
Pat.... if you started all over again, would you build an LT or an LS?
I'm on a mission to make the LS conversion less costly, less daunting. It's not as scary as you think.
KDS-Performance.com
post #28 of 28 (permalink) Old 02-12-2013, 07:17 AM
Michael,
If there's some rule limiting me to stock GM parts, then sure I'll stuff a late model 400 hp LS engine into it.
If I had to do it over again? ...No hesitation whatsoever; I'd stay LT1. For no conversion hassles, I have 525 hp on the cheap. What kind of aftermarket parts? .......just heads, cam, and ARP rod bolts. Now if you're at the mercy of someone who doesn't know how to rebuild an engine properly, then yes, you have a point--just rely on an engine that GM put together with the power you require...ie. LS. You either pay more for a later model that has the power, or you swap cams and upgrade the valvetrain in an earlier one to get the power to make the conversion worthwhile.
I still see the LS conversion as a "uniqueness" attraction for most. Unless they're guys like you and Gerry who can do it and dial it in themselves, most will get in over their head and have unimpressive results.
Don't get me wrong, I love seeing the different routes people take with their cars. It's why this hobby is so interesting compared to all the racing series that outlaw ingenuity. But, when somebody asks me what's the best power per dollar route, depending on the resources and skills they have, I'm likely to be a realist and tell them to stick with the platform that their car came with
NA: 10.98 @ 122
