Cruising rpms with T56 and 3.42's? - Chevy Impala SS Forum
post #1 of 29 (permalink) Old 01-28-2013, 12:03 PM Thread Starter
toomanytoyz's Avatar
Send a message via AIM to toomanytoyz
Hey Guys,
Yes, I know I've had a couple t56 cars and have always preached at least 4.10's but preferably 4.56's... But has anyone done it with 3.42's? I'm looking for cruising rpms at highway speed. I run a 26" tire. I have plenty of motor, and this will be a pleasure use vehicle, with much commuting duty, and it already has recent 3.42's. I'm assuming 6th will be useless under 65mph, and that's fine with me. I'm hoping the highway rpms from 70-80mph will be less than 2K rpms so I can get some really decent mileage out of it.
Also, how was it getting it going from a stop? I've driven 3.08 and 2.93 cars with the t56 and it felt fine to me.
I know someone had put together a spreadsheet with the differsnt trannies and gear ratios and tire diameter to find rpm, but I can't seem to find it now. Anyone still have it, or a link to it?
Thanks guys! Catcha later.
Bill "The Verb" Crovo - Resident Car Slut
95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner...
00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc...
94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said.
American Ricer
www.badassofne.net
"Ooooh! Look! Something shiny!"
LOWER IT!!!
toomanytoyz is offline
post #2 of 29 (permalink) Old 01-28-2013, 12:47 PM
jayoldschool's Avatar
I think the stock gears for F bodies with T56 was 3.42. You'll be fine.
jayoldschool is offline
post #3 of 29 (permalink) Old 01-28-2013, 12:55 PM
3:42 may work. the F bodys came with 3:42 with the T56
with that said the B-body weighs quite a bit more than a f body
my experience was with 3:73. It had a slight "dog" feeling off the line and even more so starting uphill so went 4:10
I suspect the 3:42's even more doggish off the line and would require more clutch slip to get going. Guy out here in SoCal did T56 swap years ago with 3:08's, burned up his clutch in a year or so of normal driving
smokemup.com has a calculator
if 3:42 you would never see 6th gear under 80 mph without lugging the car. with 4:10 at 80 mph I tach 2k rpm with a 27" tire so I leave it in 5th at 65 mph and tach about 2100
at the track I run a 26" tire so gear ratio then is 4x? (lower ratio than 4:10)
post #4 of 29 (permalink) Old 01-28-2013, 01:20 PM Thread Starter
Yeah, I knew the fbodies came with the 3.42's and a 26" tire, but as stated, I'm about 1200 pounds heavier than those. And with 4.10's, I would use 6th gears as low as 50mph, with a 26 or 27 inch tire, with no issues for cruising.
Thanks for the calculator link. I'll check it out when I get home.
American Ricer
www.badassofne.net
LOWER IT!!!
post #5 of 29 (permalink) Old 01-28-2013, 02:49 PM
Narc 9c1's Avatar
Here's the one I found on this forum: T56 and 4L60E Comparison Spreadsheet
95 9C1: Purchase Price: $1k -- T-56, AI 190cc Heads/cam, 355 Bottom End, 58mm BK TB, Intake Ported by AI, CIA Quad-1 Long Tubes w/ Export Pipes, 3:73s, Eaton Truetrac, SS Rearend (width), Eibach Springs, Bilstein Sport Shocks, PPM Front End, C3Fab 5/8 Extended Control Arms, SS Interior...
53 Studebaker Starliner: sold!
69 Grand Prix
Narc 9c1 is offline
post #6 of 29 (permalink) Old 01-28-2013, 05:13 PM
No Moa's Avatar
What ya puttin it in?
1995 9C1
06 CTS-V
2002 CETA 700 original miles.
No Moa is offline
post #7 of 29 (permalink) Old 01-28-2013, 05:46 PM
http://craig.backfire.ca/pages/autos/speed-calculator
26" Tire, 3.42, T56 with 0.74 & 0.50 OverDrives
RoadMpH 5th: 2.53 6th: 1.71
46MpH 1503 995
54MpH 1765 1169
61MpH 1994 1320
69MpH 2255 1493
77MpH 2516 1666
84MpH 2745 1818
92MpH 3007 1991
Fwiw:
4L60E * 2.56
3rd: 2.56 vs your 5th: 2.53
4th: 1.78 vs your 6th: 1.71
If my [enervating] experience with 2.56 is any indication, your 6th gear will provide negligible highway acceleration without the assistance of a tailwind, a draft, or a downhill or
more torque in the 1000-2000 RpM range than our LT1.
IMO, with a T56'd B-car, 3.73 would be the bare minimum, unless highway MpGs were the ultimate goal, or I had a more torquey engine than the mid-90s ironhead LT1.
With either 3.73 or 4.10, the extra gear could be mitigated with tires as tall as 29", which would add more rubber to grip the road.
1g1bl82p7rr127841
Rest In Pieces, In Peace
Marky Dissod is offline
post #8 of 29 (permalink) Old 01-28-2013, 06:22 PM
Sshockr's Avatar
I drove my 3.08's to nationals. It wasn't ideal but they worked, for the month I had before all the rear end parts arrived. I would guess 3.42's would be doable if you don't mind slipping it a fair bit. With 3 08's and 6th gear at 75 on a stock motor if I remember correctly I pulled down something like 28-29 mpg.
-Brian
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
Sshockr is offline
post #9 of 29 (permalink) Old 01-28-2013, 06:35 PM
IMHO, if the T56 is going in the long roof car....4:10's. The "cruise & hwy" will be way happy with 5th or 6th gear but more important is the car will not bog off the line or be a bitch pulling from a dead stop up a hill or driveway
the 3:42's will "work" in terms of just being able to drive the car but the 1200 lb weight over the f-body weight will reveal the fact you need more gear......and your clutch will last longer
post #10 of 29 (permalink) Old 01-28-2013, 06:57 PM Thread Starter
OK, that's all about what I figured. Thanks guys.
I know that I really want 4.56's, but was curious if the 3.42's would be do-able for mileage concerns. My motor is NOT stock, so if I had any shot at increasing the mileage, I was gonna take it.
I've got plenty of time to think on it...
American Ricer
www.badassofne.net
LOWER IT!!!
