Rear end bad... - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 02-14-2013, 08:27 PM Thread Starter
Send a message via AIM to fast lt1
Rear end bad...
Well my side gears inside my rear end are wearing out i believe. The axle has play in it and you can pull it out and push it in a 1/4'' or more. I don't want to drop $1,000 on a rear end, so what route should i go. My auburn is also wore out and non working. I also wouldn't mind having a new ring and pinion gear set put in like 3.73's. Anyone know of any quality rebuild kits for the rear ends?
fast lt1 is offline
post #2 of 14 (permalink) Old 02-14-2013, 08:58 PM
Rear end bad...
The factory Auburn is not re-buildable. I use/recommend the Eaton,but many like the TruTrac also. There is no inexpensive way out really. This is a good time to change the gear,this will actually save some labor. The Eaton uses a slightly different carrier bearing. You should change all the bearings anyway. Inspect the axles too. You won't regret going with the 3.73, that gear will really wake up your ride.
post #3 of 14 (permalink) Old 02-14-2013, 09:41 PM Thread Starter
What is the cheapest posi to go with? Also any reputable place to buy a set of 3.73's? And lastly what kind of stall should i run with 3.73's? Car sees a lot of highway driving. I'm running a small cam, which it needs a stall anyway cause my bottom end sucks when launching. I'm about to rebuild my trans so this is also a good time for a stall converter.
fast lt1 is offline
post #4 of 14 (permalink) Old 02-14-2013, 11:29 PM
Rear end bad...
I use/recommend a quality 9.5" converter. They are not inexpensive,but they're worth every dime. Plus,it isn't something one wants to do twice. I'm very happy with the 3000 stall Vigilante. I have stock heads/cam,headers,and 3.73 rear gears. My 60' times at the dragstrip are under 2sec.
post #5 of 14 (permalink) Old 02-15-2013, 01:14 AM Thread Starter
I was thinking a yank 2200.... Is 2200 too low?
fast lt1 is offline
post #6 of 14 (permalink) Old 02-15-2013, 10:19 AM
Rear end bad...
Is it better than what you have? Yes,but I find the 3000 Vigilante to be a vast improvement over the 2500 TCI installed previously. There would have been considerable savings if I had purchased the Vigilante to begin with.
post #7 of 14 (permalink) Old 02-15-2013, 10:32 AM
Sshockr's Avatar
I spent 1000 rebuilding my rear end 3 years ago with an Eaton, gears and an install kit. I did the install myself.
I would go bigger than 2200. I have 2400 in truck (got the converter for free) can't really tell much of a difference. Having driven well tuned 3200 and 3600 cars I wouldn't hesitate to go 3000 or bigger for a near daily driven street car.
-Brian
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
Sshockr is offline
post #8 of 14 (permalink) Old 02-15-2013, 10:49 AM
KW Baraka's Avatar
Yank makes a 2200 stall TC for GM cars ???
If they do.....it ain't on their web site.
KW
KW Baraka is offline
post #9 of 14 (permalink) Old 02-15-2013, 01:04 PM
you start out saying you don't want to "drop a $1000"....but go on to say what you "want".
the "want" will cost a $1000+
eaton diff $400
Gears $175
Reluctor gear $100
axles $125 each
master bearing kit $100+
fluids $20
Gasket $5
labor $200
If you have the skills and tools to do the labor great...but setting up gears right is knowledge/experience based
Torque converter...like girls...we all like diffrent ones. 2400-2600 stall with a mild cam, IMHO, is good compromise for street. If it is all about the track go higher. Either way consider a larger external tranny cooler addition
post #10 of 14 (permalink) Old 02-15-2013, 06:17 PM
I wouldn't base the condition on the rear diff on the in/out 'play' in the axle shafts alone. There's a certain amount of play in any C-clip style axle setup. Pull the diff cover off and actually inspect the gears. I've never seen a 10-bolt have gear problems unless it was raced or in an application needing a beefier rear end.
2005 Pontiac GTO
cletus284 is offline
