What are the signs of a Bad Water Pump? - Chevy Impala SS Forum
post #1 of 16 (permalink) Old 09-02-2010, 11:04 AM Thread Starter
STILL SLUM's Avatar
I wanted to find out if my water pump was going out, what signs to look for. The car does not overheat but after you cut it off, radiator fluid comes out of the cap. I just replaced the thermostat to see if that would fix issue but it doesn't, Any suggestions on what to look for?
1995 Caprice 4.3
STILL SLUM is offline
post #2 of 16 (permalink) Old 09-02-2010, 11:07 AM
thebigbadWOLF's Avatar
1995 Caprice 4.3
weap hole on the underside of the WP, if it leaks its bad...no warning...its bad
overheating is another sign.
if water is coming out the CAP (where the stats goes) you didnt put it on right/tight enough.
you dont need a gaskit for the stat, thats the point of that rubber around the edge of the stat.
thanks
Wolf
Cali-SS
thebigbadWOLF is offline
post #3 of 16 (permalink) Old 09-02-2010, 11:09 AM Thread Starter
STILL SLUM's Avatar
It bubbles back out of the radiator cap.
post #4 of 16 (permalink) Old 09-02-2010, 11:10 AM
the rad cap needs to be pressurized, so you could have a bad cap.
i assume you recently did some type of service....have you bleed the system?
Cali-SS
post #5 of 16 (permalink) Old 09-02-2010, 11:16 AM Thread Starter
STILL SLUM's Avatar
I just had the AC clutch removed due to it being damaged due to it grinding metal to metal until I get the entire AC compressor replaced. Nothing other than that.
post #6 of 16 (permalink) Old 09-02-2010, 11:24 AM
Replace the radiator cap. Easy fix. Use the 18# '96 Cap.
Jim B.
fbi9c1 is offline
post #7 of 16 (permalink) Old 09-02-2010, 11:27 AM Thread Starter
STILL SLUM's Avatar
I'll replace the radiator cap & repost ASAP, thanks FELLAS!!
post #8 of 16 (permalink) Old 09-02-2010, 11:29 AM Thread Starter
STILL SLUM's Avatar
Just to make sure, this is the Cap that goes on the coolant tank above the battery.
post #9 of 16 (permalink) Old 09-02-2010, 12:02 PM
Yes, that is it.
Jim B.
fbi9c1 is offline
post #10 of 16 (permalink) Old 09-02-2010, 04:00 PM Thread Starter
STILL SLUM's Avatar
I replaced the cap & the issue has stopped. I rode for 20 mins then parked & no fluid out of the cap. Thanks Guys for the $5.32 fix.
