No heat! - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 10-02-2010, 10:41 PM Thread Starter
HurricaneSSeason's Avatar
No heat!
Tried to warm my car up this morning and my heat wouldn't work. What steps do I need to take to find my problem?
1996 Impala SS DCM
SLP ram air hood, smooth bumpers, Clear Image Tri-Y headers, PCMFORLESS tuning, LT4 KM, Spin Tech Pro Street cat back, X pipe, cat delete pipes w/ cut outs, Clear Image cold-air intake, corvette engine dress, Hotchkis springs, bilstien sport shocks, 3:73 gear, eaton posi, MSD wires, clear corners, 20% tint, white face gauges
1996 Impala SS DGGM
Eibach springs, Moog bushings
1994 Caprice 9C1
Eibach springs, SS 1/4 glass, SS grill, SS spoiler, SS interior, SS wheels
HurricaneSSeason is offline
post #2 of 14 (permalink) Old 10-03-2010, 01:13 AM
What do you mean by not working? Do you mean the fan doesn't come on, or only at the slow speed? Do you mean the fan works fine but not heat comes out?
If the fan doesn't come on it may be a bad fuse, bad fan, or a bad resistor pack.
If the fan works fine but just get cold air, then most likely the heater core is clogged. You can try backflushing it but given the age of it may just want to go and replace it, and when doing it also would want to do a flush and fill of the whole radiator fluid system to get all the old coolant and debris out of the system. Also while you are in there may want to replace the flow restrictor and the T fitting that goes between the heater hoses and the coolant tank as both parts are plastic and known weak points in our cars. - Peter
Peter Cordes
1995 Caprice SS/9C1 Black w/ tan leather interior
1993 Ford Escort LX Mocha Frost Metallic w/ tan interior
pcordes1979 is offline
post #3 of 14 (permalink) Old 10-03-2010, 06:04 PM Thread Starter
the fan blows fine, but I noticed today that when I turned the cold/ hot knob so it wouldn't be so cold, it didn't make a difference. It kept blowing super cold. Is this still the heater core?
1996 Impala SS DCM
1996 Impala SS DGGM
1994 Caprice 9C1
post #4 of 14 (permalink) Old 10-03-2010, 11:22 PM
"It kept blowing super cold. Is this still the heater core?"
Yes.
Jim B.
fbi9c1 is offline
post #5 of 14 (permalink) Old 10-05-2010, 12:14 AM Thread Starter
So i'll just replace it then, should I flush it b4 or after the new heater core?
1996 Impala SS DCM
1996 Impala SS DGGM
1994 Caprice 9C1
post #6 of 14 (permalink) Old 10-05-2010, 12:31 AM
rematar's Avatar
Is your thermostat working - engine temperature up to normal?
If so your heater core could be plugged. Search in this section, there are many posts about cooling systems full of crap that will plug a new heater core in no time. You may need an extensive cooling system flush.
05 magnum rt with srt8 300 front
95 dcm wb4 rmw funeral car from fred - sold
93 white woody rmw - sold
rematar is offline
post #7 of 14 (permalink) Old 10-05-2010, 12:34 AM
Vendor
NO DUBS's Avatar
A heater core is basically a small version of a radiator. There are a tube that zigzags with fins over it. The hot coolant flows through the tube heating it and the fins. Then, you have a fan that blows across the tube and fins giving you hot air. Now if there is an obstruction in the tube, the coolant will not be able to flow through it so the fan will be blowing on a cold tube thus giving you cold air.
So your heater core that is in your vehicle is clogged. You can try to back flush it, but be careful because it is very delicate. Mabe try a garden hose only half open.
So i hope that answers your question and learns ya sumpthin
P.S. flushing a new heater core will do nothing as you probably know now
94 Impala SS with a decent amount of work
NO DUBS is offline
post #8 of 14 (permalink) Old 10-05-2010, 04:03 AM
also check the vacuum line make sure when you turn it to heat the valve actually opens the heater core
here are some pic from my car
they are under dash behind radio and ashtray assembly
ID:	15610   Click image for larger version
when you don't know what to do,do what you know
ahoora is offline
post #9 of 14 (permalink) Old 10-05-2010, 04:07 AM
here is one more pic
ahoora is offline
post #10 of 14 (permalink) Old 10-05-2010, 07:00 AM
On the Chevy's, the temperature is cable operated. The vacuum controls the level air comes out of.
2005 Pontiac GTO
cletus284 is offline
