bleeding cooling system - Chevy Impala SS Forum
post #1 of 28 (permalink) Old 02-16-2011, 07:21 PM Thread Starter
what is the proper way to bleed a cooling system?
96 Impala BBB
allwestss is offline
post #2 of 28 (permalink) Old 02-16-2011, 07:46 PM
I don't know about "proper" but here is my method. With the cooling system cold and full I open the bleeder screw and let gravity work to remove some air. Top off the system if needed, seal it up and crank engine. While waiting on it to heat up I jack up the front of car and put on stands. If you are impatient stick a dime in the throttle stop to hold the rev's up. When it's up to normal operating temps I turn off engine and open the bleeder to purge more air. A lot will come out now. Let the car cool, top off coolant level. Repeat. A third run of this never gets anymore air out for me. But it's nice to do just to be certain.
yippeekyaa is offline
post #3 of 28 (permalink) Old 02-16-2011, 08:06 PM
Nick Danger's Avatar
Buy the enhanced bleeder valve from BigBlackBeaSSt. Attach a transparent hose to the nozzle and put the other end in a bottle. Pour the coolant from the bottle back into the reservior. No mess.
Enhanced Bleeder Valve
1994 Roadmaster Wagon.
Mrs Danger's site: www.unseengallery.com
Nick Danger is offline
post #4 of 28 (permalink) Old 02-16-2011, 10:20 PM Thread Starter
thanks for all the help fellas you got me through,, i will be getting that enhanced bleeder valve asap
96 Impala BBB
post #5 of 28 (permalink) Old 02-28-2011, 08:18 AM
96WAGON's Avatar
Are the LT1 Corvettes & Camaros any different in the same years? The reason I ask is because when you do a search on bleeding an LT1 cooling system it appears all they do is open the reservoir cap, start the motor, let it warm to operating temp, check to make sure their are no air bubbles in reservoir, top off if needed. The reason I ask is because I'll be replacing an upper hose soon. Thanks!!
96WAGON is offline
post #6 of 28 (permalink) Old 02-28-2011, 10:52 AM
96SSbbb's Avatar
96SSbbb is offline
post #7 of 28 (permalink) Old 03-01-2011, 06:39 PM
bighom20's Avatar
Originally Posted by 96SSbbb View Post
Thats a nice bleeder valve, question tho in that link where does that clear tubing end at? do you let it jus dangle while driving?
94 Impala SS BBB-135k-Bagged on 20'' oasis-Sold
95 Impala SS DCM-Mostly Stock
ISSCA#2418
bighom20 is offline
post #8 of 28 (permalink) Old 03-01-2011, 07:40 PM
96SSbbb's Avatar
I ran the hose behind the water pump and attached it to a bracket under the car. But you could run the hose where ever you wanted. I'll put up some pics later.
96SSbbb is offline
post #9 of 28 (permalink) Old 03-01-2011, 07:58 PM
bighom20's Avatar
ok i defintly would like to see the set up... also the bleeder valves they sale at lowes, they just screw right in no prob?
ISSCA#2418
bighom20 is offline
post #10 of 28 (permalink) Old 03-01-2011, 08:18 PM
96SSbbb's Avatar
Just screw it in, the threads are a perfect match.
96SSbbb is offline
