Where to add freon? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 07-24-2011, 12:54 PM Thread Starter
Where to add freon?
Where exactly is the fitting on our cars do you to attach the hose to add freon ? I see two of them . I have a 96 Impala.
y-burna is offline
post #2 of 8 (permalink) Old 07-24-2011, 01:02 PM
Mr pogo's Avatar
if I tell you, will you promise to take it to a shop if the ac doesnt cool any better after you added freon?
Mr pogo is offline
post #3 of 8 (permalink) Old 07-24-2011, 01:31 PM Thread Starter
Lol....my word.
y-burna is offline
post #4 of 8 (permalink) Old 07-24-2011, 01:34 PM
Mr pogo's Avatar
you want to add it to the fitting on the acumalator , ac on and idling.
try not to over charge it, orifice tube systems are dependent on pressures to keep the evaporator from freezing.
Mr pogo is offline
post #5 of 8 (permalink) Old 07-24-2011, 01:36 PM Thread Starter
Thanx bud.
y-burna is offline
post #6 of 8 (permalink) Old 07-27-2011, 10:10 AM
FWIW - they are different sizes - it only fits on one.
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
grandpas wagon is offline
post #7 of 8 (permalink) Old 07-27-2011, 06:04 PM
JVL96's Avatar
I just did mine today, if you want to do it right buy a new accumulator, install it, do a vaccum check, then add the freon (the port is on the side of the accumulator that points torwards the battery.
96 BBB SS (#40,269 of 41,934) Custom Heads Up Display and T56 limp mode delete
94 SS (#240 of 6303)
86 C10 Silverado (winter beater)
JVL96 is offline
post #8 of 8 (permalink) Old 07-27-2011, 07:49 PM
ghetto wagon's Avatar
If you have a small leak, Adding some R-134a is fine. It will get you by for even a few years.. If you find a spot somewhere in the system that is wet with compressor oil, You have a big leak and its best to service the system.
The Fill side (Low pressure side) is on the Accumulator or receiver drier depending what you want to call it. The High side port (Dont touch that when charging) is near the battery/ coolant tank screwed into the high side pressure line.
When the low side is around 30 PSI on a decently hot day, It should have enough R134a added.
Previously known as having the highest post count on Impala SS forum
The forum is dead
So is the car's battery from sitting.
Waiting for someone to jump it. Tabarnak!
ghetto wagon is offline
