did a new water pump install,forgot o rings... - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 02-13-2012, 11:44 AM Thread Starter
superboosted's Avatar
Do I need to pull the pump back off? Is this the end? On the pump drive BTW please say its ok,I don't want to pull it apart again.
1996 Caprice Classic B4U
SS wheels,resonators removed,side trim removed,ecu tune,hawk pads,Goodyear hoses,A.I.R. removed...for starters.
superboosted is offline
post #2 of 6 (permalink) Old 02-13-2012, 01:55 PM
pull it off and install the o-rings. It can be a pain but Id do it if I were you.
95 DCM Imp SS....Daily Driver 98k and counting
72 Cutty............Weekend cruiser.
Nor-CalSS is offline
post #3 of 6 (permalink) Old 02-13-2012, 03:42 PM
I just did a water pump replacement and it seems those o rings are very durable. whats year is your impala? I wouldnt sweat it.
561 B-Body Boy is offline
post #4 of 6 (permalink) Old 02-13-2012, 03:46 PM Thread Starter
Well,I think I am going to wait a.week or two as I have to tear it down again to convert to electric fans and change opti/wires,looks like all it does is keep out dirt?
Also need to decide if I want to keep the ac pump as that is squeaking now of course.
post #5 of 6 (permalink) Old 02-13-2012, 03:58 PM
Mr pogo's Avatar
youre supposed to grease the coupler splines on reassembly and the o-rings keep the grease in and moisture out.
without the grease or in high moisture areas the coupler rusts to the splines.
Mr pogo is offline
post #6 of 6 (permalink) Old 02-13-2012, 04:03 PM
You do need to replace the o-rings and you should pack the shaft connector with wheel bearing grease.
Jim B.
fbi9c1 is offline
