Fans - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 04-16-2012, 04:17 PM Thread Starter
Fans
Hi, Newby here.
Just got my first Caprice. It's a 1994 Wagon with LT-1.
One question: why do some of these cars have electric cooling fans like mine, and I've seen others, same year that has a mechanical one (belt driven)?
bigbluebus2500 is offline
post #2 of 6 (permalink) Old 04-16-2012, 07:06 PM
Cars equipped with HD cooling (RPO V08) have a primary mechanical fan and secondary electric. Cars with base cooling or extra-capacity cooling (RPO V03) have dual electrics.
2005 Pontiac GTO
cletus284 is offline
post #3 of 6 (permalink) Old 04-16-2012, 08:49 PM Thread Starter
Thanks for the reply; one more thing: So if it has a belt driven fan and shroud...can I automatically assume it has the heavy duty cooling, like for towing? Does it also include an extra trans cooler? Does RPO V08 also include a heavy duty radiator as well?
Is there a difference between base cooling and extra-capacity cooling?
post #4 of 6 (permalink) Old 04-16-2012, 10:24 PM
Read all about it:
http://www.theherd.com/forum/topic.asp?TOPIC_ID=112
Then check the tab on top for other tech articles. That will keep you busy a while. Welcome to the forum.
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
grandpas wagon is offline
post #5 of 6 (permalink) Old 04-16-2012, 11:19 PM Thread Starter
Thumbs up
Originally Posted by grandpas wagon View Post
Read all about it:
Then check the tab on top for other tech articles. That will keep you busy a hile. Welcome to the forum.
Wow...what a great article.
Thank You!
post #6 of 6 (permalink) Old 04-17-2012, 09:09 PM
The V92 tow pack always includes V08 cooling, which always includes the mech fan [which incurs a 10 peak horse penalty].
Technically, no. All 94-96 B-cars have an integral transmission cooler close-coupled to the radiator.
All LT1 B- & D- cars also have an additional external transmission oil cooler.
Couldn't tell you. These days, the only radiator variants I can find are:
civilian radiator with integral motor oil & transmission oil coolers
9C1 radiator with integral transmission oil cooler only, no oil cooler
(On this, I could be misinformed.)
The base cooling option was a 150W primary fan, and a 100W 2ndary fan.
The V03 cooling option upgraded the 2ndary fan to 240W.
The V08 cooling option that came with the V92 tow pack upgraded the primary fan from a 150W elec fan to a 7,457W mechanical fan, and kept the 240W 2ndary.
1g1bl82p7rr127841
Rest In Pieces, In Peace
Marky Dissod is offline
