Defroster fuse - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 11-26-2012, 08:33 PM Thread Starter
Defroster fuse
Hey folks,
I am in need of a new defroster breaker fuse. I have searched at all the local auto parts stores without any luck. I have found it on ebay, but 10.00 for a fuse is pretty ridiculous ( http://www.ebay.com/itm/New-OEM-Mini...00332188732%26 ). Considering it is a common fuse for almost any GM vehicle, you would think it would be stocked in stores. Part # is 12077843 mini circuit breaker 14.5 volt 30A. I could just use a regular 30A mini fuse but I would think that if GM would have wanted us to use a normal fuse, why not put it there in the first place. Am I not typing the correct words in the search field? HELP!
thanks
Chris
'94 LDM Caprice Classic L99
ISSCA Member #2309
94goldprice is offline
post #2 of 8 (permalink) Old 11-26-2012, 10:20 PM
Defroster fuse
Wouldn't any salvage yard have plenty available?
post #3 of 8 (permalink) Old 11-27-2012, 08:03 PM Thread Starter
fuses and bulbs are usually the first thing picked clean around my parts
ISSCA Member #2309
post #4 of 8 (permalink) Old 11-27-2012, 09:28 PM
1phastss's Avatar
Chris,
The defroster uses a circuit breaker, I have seen a few guys replace the circuit breaker with (like you mentioned) a traditional style fuse, and not have run into any problems. After years of use the original breaker wears down, and eventually out, using a std fuse should be ok as long as you dont keep on hitting the power button over and over
CarISSMA (Carolinas Impala SS Motor Association) President
1991 White LSX Wagon - (HIS) A.K.A "The Abomination" / Reaper
1991 White SS Wagon - (HERS) SS Nose-SS Wheels-3.23 POSI-Clear Corners-Silverstars-Tinted Windows
ISSCA Member #2499
1phastss is offline
post #5 of 8 (permalink) Old 11-28-2012, 11:45 AM
imp1996's Avatar
Send a message via Yahoo to imp1996
Originally Posted by 1phastss View Post
Chris,
Where exactly is the circuit breaker for defrost?
And still wit a beaSSt!!
CHEVY_BOI-229 4 LIFE!!!
UGA FOOTBALL #96
SSPEEDIN........
1996 impala ss 350 LT1 DGGM
STOCKIE!!!!! well not really, flowmaster 40's 8000k HIDs and sum nice **** in the trunk.
imp1996 is offline
post #6 of 8 (permalink) Old 11-28-2012, 12:19 PM
Its in the fuse panel on the left side of the dash.
*See Right Side Of Picture That Says Circuit Breakers*
95 DCM Imp SS....Daily Driver 98k and counting
72 Cutty............Weekend cruiser.
Nor-CalSS is offline
post #7 of 8 (permalink) Old 11-28-2012, 12:43 PM
Defroster fuse
I think the poster is referring to the rear defogger. It's probably on a breaker because of high-amp draw,along with seldom use. If left on,or if the beaker just trips. The next time you try using it, it will still work. I don't see anything wrong with using a fuse,unless it just blows them easily. Either way,you know what it is. I'd try it.
post #8 of 8 (permalink) Old 11-28-2012, 07:49 PM Thread Starter
Thanks guys,
I was just hoping someone had a website hookup for these. After doing a search here I have seen posts on the subject but with no listing on where they got them. Standard mini fuses are cheap, I was just worried the original breakers had a much greater purpose. Thanks for the advice guys.
Chris
ISSCA Member #2309
