heat not working - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 12-28-2012, 06:28 PM Thread Starter
Ztater's Avatar
heat not working
the heater on my car works for a few seconds and then gets cool if i turn the heater fan down for a min and then turn it back on its hot again but only for a lil bit then cool again any trouble shooting that i can do
95 caprice
Ztater is offline
post #2 of 11 (permalink) Old 12-28-2012, 06:46 PM
jking1118's Avatar
I'm a former member of the no heat club
Jonathan
jking1118 is offline
post #3 of 11 (permalink) Old 12-29-2012, 11:09 AM
st95ss's Avatar
look, listen & learn bruh, this is the best site, welcome
95 DCM Impala SS, G2 Cold Air Induction,G2 power pulley kit w/ v-belt ,G2 throttle body plate, G2 air foil,G2 Valve Cover Breather,pcmperformance tune, 160 thermostat,Borla Full Stainless Steel Exhaust, tri-y headers, 12 way Bonnie, air pump delete, 91 Caprice tailights SSittin on TIS 06's 22's
# 3,683 of 18,365
http://www.cardomain.com/ride/229728...ellville-ga-us
st95ss is offline
post #4 of 11 (permalink) Old 12-29-2012, 10:13 PM Thread Starter
Ztater's Avatar
i flushed the coolant about 10000 miles ago when i replaced my opti the coolant is still green and looks to be in great shape
95 caprice
Ztater is offline
post #5 of 11 (permalink) Old 12-29-2012, 10:29 PM
Crime Scene 96's Avatar
Its been well documented that coolant flushes could take several attempts.
Has your heater hose assembly been replaced? Also when the flush was done, how was it done or did a mechanic/dealer do the job for you?
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
Crime Scene 96 is offline
post #6 of 11 (permalink) Old 12-30-2012, 09:40 PM
Try reversing the hoses. Worked for me.
'96 SS - 12.887 at 103.06 mph with a 1.675 60-ft. Member of the "12-Second Bolt-On Club "
Yep. That is Ashley Force.
MUSSCLE in Milwaukee is offline
post #7 of 11 (permalink) Old 01-01-2013, 04:24 PM
Did you pressure flush the heater core as part of this? If not, it's still full of crud.
2005 Pontiac GTO
cletus284 is offline
post #8 of 11 (permalink) Old 01-01-2013, 10:36 PM
BBODYLT1's Avatar
Send a message via AIM to BBODYLT1
Yeah I would definitely back flush the heater core, simply remove one of the hoses leading to the fire wall then use a garden hose on full blast to flush the crap out. I've done this on all the caprices I've owned, after that I could only use the heat on the lowest setting because it was to hot...lol
99 Regal GS
HDI cold air|Gen-V Supercharger|3.5 Pulley|N* TB|LQ4 MAF|Drilled 180 t-stat|AL104 plugs|PJR wires|Alt rewire|9c1 Trans cooler|3.29 gears|TOG headers no cat no res|GTP dual exhuast|GTP trans mount|Flipped M/M's|Monte braces|Rear strut tower bar|GMPP Front-rear sway bars|GMPP trailing arms|9c1 struts|C-5 Corvette brakes|GTP HUD|05 GTP seats|Custom tuned.
BBODYLT1 is offline
post #9 of 11 (permalink) Old 01-02-2013, 02:57 PM
Dan Fahey's Avatar
YUP..I put in my 3rd Heater Core..
The first two were cheap replacements..
I bought a Delphi Heater Core this time and paid a little more.
Now I have to use th lowest setting..
Time for a new Motor and it buzzes a little \
D
Dan Fahey is offline
post #10 of 11 (permalink) Old 01-06-2013, 08:59 AM
st95ss's Avatar
Talking
last week got in the whip and turned heater on, cold was pouring out, thought I was in Alaska, it was so cold, took it to Byrons and they changed a couple of hoses and sucked some gunk out and that baby, feels like in in Hawaii, thought I would share this seeing that I drive the whip every 3 1/2 to 4 months when I get here
# 3,683 of 18,365
st95ss is offline
