Flex-a-lite part no. 480 - A/C turn on question - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 01-23-2013, 06:06 PM Thread Starter
Berns's Avatar
Hello All,
I have read threads on electric fan conversions on 91-93 B-Bodies and it seems that there are people for it and people against it. I have a friend who has a NIB flex-a-lite set up part 480. I verified with Flex-a-lite directly and it can be used on my car and comes with all brackets, wires and control box. My question is that when I asked the tech about the A/C turn on switch he said I can use a t-tap connector and splice into the hot wire going to the A/C compressor and hook up the wire from the control box to the this connection and this will turn on the fans each time I turn on my A/C, tech suggested I solder joint instead of using the t-tap connector though.
Has anyone done it this way or should I stick to my mechanical fan (hate the roar on start up). I can get the set up for cheap but don't want to ruin my ride by using it. Any thoughts.
1993 Caprice LTZ/LS
Smoked headlight, tinted 91 tails, LED interior and exterior, JET chipped, MSD ignition, sounds with Kenwood unit, 20" IROCS w/ 255/35 20 Falkens, dual after cat exhaust and bowtie tips, modded air box, WAY MORE TO COME.....
Berns is offline
post #2 of 5 (permalink) Old 01-23-2013, 07:16 PM
1FAST94's Avatar
Heating/Cooling/HVAC Try here. There is no relationship to performance in what you ask.
Mike Harris
B-BODY PERFORMANCE
Dayton, Ohio
10.43 @126.95 @ 3800 lbs.
http://www.youtube.com/watch?feature...&v=a8dYCl2cAdM
1FAST94 is offline
post #3 of 5 (permalink) Old 01-23-2013, 09:05 PM
Fishah's Avatar
I did it the way the your guy at Flex-A-Lite suggested. Was foolproof for the 5 years I had the car.
I'm pretty sure FlexALite #395 is the right unit for the TBI, but I suppose that doesnt mean the 480 won't work. +
Bill Fisher
Fishah is offline
post #4 of 5 (permalink) Old 01-24-2013, 02:06 PM Thread Starter
Berns's Avatar
Just the answer I was looking for. I don't know why some people are against it. I think they blow up their engine by not hooking up the a/c wire and then cruise with the a/c on and overheating.
I tried searching for # 395 but could not find it. If I can get the correct one I would rather spend the extra $$ and get it done right.
1993 Caprice LTZ/LS
Berns is offline
post #5 of 5 (permalink) Old 01-24-2013, 02:19 PM
Fishah's Avatar
Whoops! I meant the #295. Been a while
Found an old thread on NAISSO from 2005 that I commented on.
http://www.impalaclub.com/naisso/for...TOPIC_ID=31812
The #295 is not a direct bolt on (none of the flex-a-lite fans are), but from what I remember the sizing was the closest to the TBI radiator and was what they reccomended 7 years ago.
Bill Fisher
Fishah is offline
