Bypassing heater core - Chevy Impala SS Forum
post #1 of 22 (permalink) Old 02-25-2013, 10:24 AM Thread Starter
The Lazy Destroyer's Avatar
I read through a couple threads on this but the ones I saw did not have a solid conclusion, so I wanted to make sure I am not doing anything wrong, or if there is a better way to do this.
I need to bypass the heater core and am thinking of making a small section of tubing on the heater core outlet/inlet connections at the water pump.
The setup: WP outlet immediately to the stock restrictor orifice, then to the stock "T" (with the side outlet going to the reservoir tank), then back to the WP return connection.
I will probably keep the 3/4" line going to the tank somewhat low, similar to the stock setup.
I'm assuming if I do this, it should not be a problem since it's effectively identical to the stock setup, just with the heater core removed and hoses shorter.
But would like to check to see if it can be done differently.
-Blake
________Motoception Photography________
"Those who possess power define those who are powerless."
95 Caprice 9C1, 12.9 @ 103 mph, 1.74 60' - Bolt-ons car
96 Caprice Wagon - "Nomad SS"
94 RMW woody
The Lazy Destroyer is offline
post #2 of 22 (permalink) Old 02-25-2013, 10:39 AM
Why are you looking to do this, leaking Heater Core? I had a similar issue on an old hoopty and it was too much work to replace the Core and I just looped the two connections together with a Hose Coupler and a couple of clamps. Pulled the hoses at the HC firewall area and coupled them together. If was fine, just not fun having heat in the winter and those little electric plugin heaters dont do squat.
I suppose you could do the same theng as long as its in between the T-Fitting on the Tank and the firewall which esentially bypasses the HC. Dont think you even need to include the restrictor since I think its purpose is to limit flow to the Heater Core. Just a question of where you want to splice it in and loop the 2 hoses.
But really, why not replace the HC if its leaking? Its not a fun job but is pretty easy to do once you check some of the threads. I recently did mine and it was pretty easy with the passenger seat out. On a good car I would rather replace the HC, on a $400 hoopty....not so much.
post #3 of 22 (permalink) Old 02-25-2013, 10:47 AM
Gacob's Avatar
This is exactly what I did. Worked fine.
Gacob is offline
post #4 of 22 (permalink) Old 02-25-2013, 10:47 AM Thread Starter
HVAC system is removed
So there is no heater core.
The quick and easy way to do it would be to just loop it at the firewall, but I wanted to remove the mess of hoses on the passenger side of the engine bay.
My goal is to have the area beside the header and alternator cleaned up. So I'd like to have my bypass hoses right there at the water pump connections.
-Blake
94 RMW woody
post #5 of 22 (permalink) Old 02-25-2013, 11:07 AM
Banned
A really cleaner way would be to remove the outlet tubes from the pump and put plugs right in the pump itself there. No ugly hose loop.
DougDePew is offline
post #6 of 22 (permalink) Old 02-25-2013, 11:48 AM Thread Starter
What would be the best way to pipe in the reservoir to the system then?
-Blake
94 RMW woody
post #7 of 22 (permalink) Old 02-25-2013, 11:54 AM
Banned
Good point. I'm still stuck in my old-school ways too often
post #8 of 22 (permalink) Old 02-25-2013, 12:06 PM
The easiest way I've found is by using AN-10 hose/fittings to construct the "bypass-loop" in such a way that when the loop is broken,the heater hoses are easily connected. The car will run hotter with the heater core bypassed.
1slow96 is online now
post #9 of 22 (permalink) Old 02-25-2013, 12:11 PM
Ok, now I see what you were thinking.
If you look at how the hoses are run, I guess you could just come off the other side of the Tee Fitting and then down to the Lower WP fitting to complete the circuit. Then just remove the HC hoses that run along the passenger side of the engine to the firewall.
How you choose to bypass the HC hose and setup is probably up to you and how creative you want to get.....different tee of some sort? Just make sure that the cooling circuit is still tied together the same way but with the 2 HC hoses removed.
The Tee works better on the other side of the Alternator bracket since you can mount the hoses there and secure them. Then use maybe a 180* bend of pipe or maybe there is a plastic fitting for this. But if you want to move things forward of that, you may have to get creative with the hose coming off the tank to the tee fitting and then somehow mount the hoses securly so they dont get caught up in the accessories.
Add a pic of what you come up with.
post #10 of 22 (permalink) Old 02-25-2013, 01:20 PM Thread Starter
Is this because the HC ability to transfer the heat to the surrounding air? I'm not sure of any other ways the HC can help cool the system down. I thought the HC wouldn't provide much cooling ability unless the HVAC fans were on, since otherwise it just sits in it's own chamber building up heat? My Mezierre HD is capable of 50gpm but I think the flow restrictor limits what the heater core sees to 5gpm max.
I suppose instead of running to the HC I could run to a small external radiator, but then I'd lose some of the simplicity I'm after.
-Blake
94 RMW woody
