Best way to run power wire into the cabin? - Chevy Impala SS Forum
post #1 of 19 (permalink) Old 12-06-2011, 09:53 PM Thread Starter
chapel's Avatar
Just curious, what's the best way to get power wire into the car? Is there any existing firewall grommets that are big enough to safely feed wire through?
1995 Buick Roadmaster Limited Estate Wagon
BATTLE WAGON
chapel is offline
post #2 of 19 (permalink) Old 12-06-2011, 10:43 PM
On the engine side of the firewall. Under the brake booster pull the foam junk foward and its 8-10 inches below the booster. youll see an oval shaped plug about the size of your thumb
6spdImpala is offline
post #3 of 19 (permalink) Old 12-06-2011, 10:53 PM
ejschultz's Avatar
^^^This. It's large enough for a single run of 1/0. I also managed to squeeze the wire for my siren for my alarm through it. It's easily accessible from the inside of the car as well. The only downside to it is it's on the driver side and the battery is on the passenger side. I had to run a full 20 foot package of 1/0 to reach the trunk.
-94 Caprice Classic LS - system, Gary's wires, 200 amp alt, tint, first base/home plate delete, clear corners w/green parking lights, LTZ hood emblem, SS springs
-97 Grand Cherokee TSi - 4" IRO lift, OEM skids/hooks/hitch, sliders, 31s, rear locker, system, tint, cloth, clear corners, Magnaflow stuff
Refs: DesertDawg, 214Texas, QUICKSSILVER, SSon22s, MadMav, gary burton
ejschultz is offline
post #4 of 19 (permalink) Old 12-06-2011, 11:05 PM Thread Starter
chapel's Avatar
thanks.
where's a good grounding point in the trunk of the wagons?
BATTLE WAGON
chapel is offline
post #5 of 19 (permalink) Old 12-07-2011, 05:22 AM
ejschultz's Avatar
You could ground to a seatbelt bolt. You'd have to make sure you clean all the sticky stuff off the bolt. GM used a "gummy" sticker then put the bolt through that to create a seal. If you really want to do it right, ground it to the seatbelt bolt and crawl underneath the car and ground that seatbelt bolt the the chassis. Or, you could find an inconspicuous place to drill and run the ground wire directly through the floor to the chassis. I'd personally rather not drill a hole like that though. That's why I'd rather ground the back side of the seatbelt bolt to the chassis.
post #6 of 19 (permalink) Old 02-07-2012, 09:49 PM Thread Starter
chapel's Avatar
I'll have to see how much cable I have... didn't occur to me that I'd need to run 20' of cable... most cars aren't that long
BATTLE WAGON
chapel is offline
post #7 of 19 (permalink) Old 02-08-2012, 11:18 AM
Capriceboi's Avatar
Hey I have always gone through the passenger side. If you pull back the carpet and firewall on the inside i do believe there is a spot there that takes you right into the engine bay under the AC lines. Or maybe I drilled it, I forget but worth checking!
Reppin' that East Coast
Capriceboi is offline
post #8 of 19 (permalink) Old 02-08-2012, 11:21 AM
96hvychvySs's Avatar
I have a 17' Rockford kit..just run on the passenger side..my pics and write up
Running rockford 1/0 gage wire on passenger side
96hvychvySs is offline
post #9 of 19 (permalink) Old 02-08-2012, 01:49 PM
stills's Avatar
1/o on the drivers side:
inside:
trunk:
stills is offline
post #10 of 19 (permalink) Old 02-10-2012, 10:56 PM Thread Starter
chapel's Avatar
awesome pics. thanks for the assist
BATTLE WAGON
chapel is offline
