Random Misfire PO300 - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 11-14-2011, 09:51 PM Thread Starter
I have been having engine trouble for quite a while now. Car runs great when its cool. After about 30-40 minutes of driving I get the check engine light. Scan comes up with PO300 which is a random misfire. Car is mostly stock with minor upgrades. Some friends told me to replace the intake manifold gasket. WHat do you guys think?
Joebucks is offline
post #2 of 5 (permalink) Old 11-14-2011, 10:09 PM
I used to have the same Random Misfire (P0300) problem. Changed my wires and spark plugs (NGK IridiumIX), haven't had a problem since
96 Impala SS BBB - Original Owner Custom Modified - Lost to Hurricane Sandy on 10/29/2012
96 Impala SS BBB - Purchased 12/23/12 with 38K on odometer
67 Impala SS - Custom Modified
Nassim is offline
post #3 of 5 (permalink) Old 11-14-2011, 10:14 PM Thread Starter
I already changed the plugs, wires, optispark and crank sensor.
Joebucks is offline
post #4 of 5 (permalink) Old 11-15-2011, 09:44 AM
angelo's Avatar
First off Welcome Joebucks !!!
the helpful folks will see this if it's in the proper section ie.... problems/maintenance
Try and use this section to say Hey i'm new What's up !?
lastly i am guessing you have a 96 caprice cuz that's a obdII code, therefore instead of throwing parts at the car I suggest you get a scanner or take it to the shop so they can see what is happening when it goes from open loop to closed loop, as that is when you say the problem starts.
BTW my P0300 was #3 Fuel injector needed to be cleaned and i was fine after that....
Search P0300 and read a ton of threads about the various things that set that code.
GL
-ALF out....
ECIRS #427 ISSCA #01978
96 WX3 DGGM Bone Stock except Bilstein 0929/1104 odom fade mod, FB & HP delete, lower bushing mod,Stealth Brake Bolt mod,9C1 air dams,160 stat,TB-Bypass,Hi-Miler Hoses,Taylor wires,SStudio TB Boot & K&N,Bonnies,Pypes-X,Spintech Super Pro Streets
CLICK ME !!!
angelo is offline
post #5 of 5 (permalink) Old 11-17-2011, 10:41 PM Thread Starter
Thanks Angelo. I have a 96 Impala. I'll try cleaning the injectors. If that doesn't work I'll try changing the intake manifold gasket.
Joebucks is offline
