Whats gas does your car like best - Chevy Impala SS Forum
 7Likes
post #1 of 49 (permalink) Old 11-18-2016, 06:31 PM Thread Starter
Dutchess B Body's Avatar
What gas brand does your B/D body run best on?. Some of you may already know most gas stations get gas from the same storage terminals including unbranded stations, but each brand gets
it's own additive/detergent package before being delivered to station. With that being said my Roadmaster likes exxonmobil/valero/shell the best. One shell station in particular my car is as happy as a pig in **** when I fill it up there.
Dutchess B Body is offline
post #2 of 49 (permalink) Old 11-19-2016, 07:06 AM
Mine does not seem to notice any difference. The additives for each brand are different for each brand, but must meet minimum federal standards. Some stations may use a generic gas, but the brand name stations have their own blend. The detergents are probably the difference.
Using premium in a car that only needs regular is a waste of money. The car does not know the difference, unless it is a lower octane rating than advertised on the pump, and you are pumping the required minimum octane rating for the car.
Should you get a lower octane rated gas, the car will have a tendency to "knock", and that will cause the timing to retard, consequently causing lower performance.
Fred Kiehl is online now
post #3 of 49 (permalink) Old 11-19-2016, 08:39 AM
popo8's Avatar
Sunoco for me... and also...LT1s are a high compression motor and require premium for optimal performance as well as the longevity of the motor. Its how they were designed.
************ IS my drug...
OWNER/ADMIN
1996 Impala SS: LE1 H/C by Lloyd Elliot. CPT "race" trans. Long tube headers, with off road X pipe.
popo8 is offline
post #4 of 49 (permalink) Old 11-19-2016, 09:23 AM
angelo's Avatar
OWNER/ADMIN
I don't think i agree with the "they need Super" comment.
Especially a B/D body, you must be talkin F and Y body.
I have been going to Citgo , the CEL seems to turn off more when i go there.
supermarket gas station is the worse around here...YMMV.
-ALF out..
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #5 of 49 (permalink) Old 11-19-2016, 11:10 AM
popo8's Avatar
-ALF out..
You dont have to agree... fact is... as you add compression you must add octane.
Ur SEL light shouldnt ever be on... so thats not really a great point to make.
OWNER/ADMIN
popo8 is offline
post #6 of 49 (permalink) Old 11-19-2016, 11:19 AM
The B-Body LT1 was designed to run on 87. A stock one doesn't need or benefit from premium.
threeimpalas is offline
post #7 of 49 (permalink) Old 11-19-2016, 11:21 AM
jasonlachapelle's Avatar
The iron head LT1 does not need more than 87 octane fuel on the stock tune. If you can find a good ethanol free 87 Oct fuel in your area, go for it.
Jason
1996 Roadmaster Wagon
1995 Caprice Wagon
jasonlachapelle is offline
post #8 of 49 (permalink) Old 11-19-2016, 11:58 AM
Jason is correct. The fact that you think otherwise simply means you are ignorant of the purpose of the LT-1's reverse flow cooling system. That was the whole idea, to allow both high compression and low octane. You also don't seem to grasp that the PCM can be tuned for higher octane if you desire to run it and there is some mild performance gain in doing so. As far as gasolines go, the important thing is to use a Tier 1 brand and that is not necessarily only the expensive ones. ARCO here is Tier 1 and Valero may now be also. I have always run a tank of Chevron with Techron through the system every couple of months as the Techron will keep your injectors clean. Hopefully you will have learned something here. The high compression needs high octane argument does not apply to these engines and there is no point in arguing to the contrary.
popo8 likes this.
Jim B.
fbi9c1 is offline
post #9 of 49 (permalink) Old 11-19-2016, 12:07 PM
I've wondered about this. I figured cop cars (9c1) are made to run on 87 & glorified cop cars (impalass) run on premium.
Sent from my Commodore64, excuse typos & brevity.
'A determined soul will do more with a rusty monkey wrench than a loafer will accomplish with all the tools in a machine shop.' -Robert Hughes
86 9C1 Blue
95 9C1 Sapphire Blue
96 9C1 White
ncinirator is offline
post #10 of 49 (permalink) Old 11-19-2016, 12:49 PM
There is no difference in the drive train of a LT-1 9C1 and an ImpalaSS.
Jim B.
fbi9c1 is offline
