Shut off when put in reverse - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 04-12-2017, 07:54 PM Thread Starter
Occasionally my l99 Caprice shuts off when it's warm and I put it in reverse. Any ideas ?
MijayPadilla96 is offline
post #2 of 7 (permalink) Old 05-11-2017, 03:17 AM
shudahadaV8's Avatar
Not enough info. Do you mean the transmission bogs down the engine and stalls it or do you mean it simply dies, like you turned the key off?
shudahadaV8 is offline
post #3 of 7 (permalink) Old 05-14-2017, 07:54 PM
RefineryRob's Avatar
Me Too!!
Hey just chiming in with my experience.
This has happened about once a month. When i throw it in reverse...the rpm drops and the car just dies. Its not an abrupt stall but it seems the rpm's drop so much the car stalls.
I start it right back up, do it again and its fine for the next 4-6 weeks.
Rob.
ISSCA Member #2482
1996 Impala BBB: SLP Headers. K&N FIPK, Eibach Pro Kit, ZQ8s. Bilsteins. Gary's Opti, Battery, and Headlight Harness'. Vette Starter. Taylor ThunderVolts. NGKs. Stealth & Metering Bolt. Goodridge Brake lines. TB Bypass. Magnaflow CATs. Air delete. Alex Tune. DynoMax 959's. CrownVic MMC drive shaft. BMR Ext'd RCA's. 373's/Superbrute
GOALS: Road Race Trans/TC, LE1 or AI Heads and CAM.
RefineryRob is offline
post #4 of 7 (permalink) Old 05-15-2017, 12:52 AM
Guys. Not a lot of info to analyze, but I'll tell you what crossed my mind. The load on the engine is greater in reverse in the following way. The engine runs the transmission pump. Reverse demands a considerable increase in the transmission fluid pressure. This is accomplished by changing valves in the transmission that ultimately does load down the engine more than when in neutral or drive (car not yet moving). The ECM compensates for this by adjusting the running condition of the engine (tries to hold the idle). Now that doesn't say what is wrong, it just maybe helps you think about cause and effect.
Could be a transmission issue or an ECM compensation problem. A vacuum leak could be at fault as when the transmission loads down the engine in reverse, at low idle speeds, the ECM can't get back to a sane condition (mixture) because the proportion of unknown air to known air is too great. Hey ... nuts maybe, but I'd actually start there (vacuum), or somewhere where air and fuel mix matters at low RPM under load.
post #5 of 7 (permalink) Old 05-15-2017, 11:44 AM
Z09B4U's Avatar
There is another resent thread that had a bad ground that failed when the reverse lights came on and killed the fuel pump.
Z09B4U
Z09B4U is offline
post #6 of 7 (permalink) Old 05-15-2017, 11:08 PM Thread Starter
It bogs down when it is put in reverse. I don't have any other vacuum related issues. Low idle she's fine. I just thought it could be something way worse. It's an intermittent thing once every couple weeks
post #7 of 7 (permalink) Old 05-16-2017, 07:39 AM
....when it's warm...
The little piece above is not particularly applicable, but the bogging/dying in reverse sounds similar to a past issue with Tribute/Escapes that pointed to the IAC.
In the absence of other useful background on the car I would go for a basic scan for history codes at an OR/AZ/NAPA. And, other expected service items I'd be checking for no other reason would be PCV, EGR, the often rotted/vanished purge system hose splice at the tank, purge solenoid itself.....all that sorta stuff.
A couple smaller flubs can sometimes line up to cause an intermittent. Let everyone know what it turned out. The thread title is good with doing a future search eh.
