What to do - Page 3 - Chevy Impala SS Forum
post #21 of 40 (permalink) Old 11-28-2012, 11:22 PM
You need to lube the 11 chassis grease fittings everytime you change the oil. There is no cap on the radiator. The coolant reservoir is part of the pressurized system and the 15lb pressure cap is on it. It is a 9c1 with LT1 per compnine.com and has 3.08 gears and is a pegleg (non-Posi). The VIN is 1G1B"L" not "1". Buy a Haynes Manual or FSM before you start working on the car and read Qalo's handbook as suggested. FYI the ImpalaSS Wx3 is an option on a Caprice not a separate car line. The green hoses are superior to the black ones that would have come with the SS option. Some of us actually like 9c1's better but since you are so concerned with lowering it, I presume you are not one of us.
Jim B.
fbi9c1 is offline
post #22 of 40 (permalink) Old 11-28-2012, 11:38 PM Thread Starter
oh yea i forgot bout the chassis...i need to get a grease gun but what grease to get?....im gettin tires this week with alignment....one of us???
showtime is offline
post #23 of 40 (permalink) Old 11-28-2012, 11:45 PM
"one of us??? "
9c1 enthusiasts that is
Jim B.
fbi9c1 is offline
post #24 of 40 (permalink) Old 11-28-2012, 11:55 PM Thread Starter
now here's what i do get....i ran the vin through vehicle history texas dot com and the first time it said impala and i ran it the next day and it said caprice classic..am i better off going thru carfax or to a chevy dealer??? or just ****ing sell the car and start over??
showtime is offline
post #25 of 40 (permalink) Old 11-29-2012, 04:38 AM
Mr pogo's Avatar
Originally Posted by showtime View Post
i bought it from a co worker and he told me its a impala but a week after i bought it he told me its a impala clone.
technically thats fraud, up to you what you want to do about it.
maybe make him buy it back or refund a good chunk of the purchase price back or take him to small claims court if they have them in your state.
next time, research first then purchase.
compnine still works
Vehicle: CAPRICE CLASSIC 4 DR
Year: 1995
Build Date: 1995-03-07
Found 87,150 vehicles matching your year and model in our database.
RPO
Description
UM7
RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7)
UQ0
SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL STANDARD RANGE PACKAGE SHELF/QUARTER 4 SPKR SYS(UQ0)
UQ1
RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
U11
CLUSTER,INSTRUMENT,POLICE CERTIFIED SPEEDOMETER(SEO) SEO POLICE INST CSTR(U11)
U73
ANTENNA,FIXED FIXED ANT(U73)
VK3
LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VM3
LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
VQ1
FLEET PROGRAM - DEALER ASSISTANCE, WITH HOLDBACK
V03
COOLING SYSTEM,EXTRA CAPACITY EXTRA CAPACITY CLG(V03)
V73
VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WU1
SWITCH INSTRUMENTATION LIGHTING SHUTOFF INSTRUMENT LIGHTING SHUTOFF SWITCH(WU1)
YK6
IDENTIFICATION - (SEO)
Y1Q
SEO COLOR - BLACK
01L
EXTERIOR COLOR,SECONDARY SPECIAL (01L)
01U
EXTERIOR COLOR,PRIMARY,SPECIAL OVERRIDE (01U)
1AA
SALES INCENTIVE - RETAIL AMENITIES -- DELETE
1K5
TRANSMISSION LOW GEAR BLOCKOUT SEO LOW GEAR BLOCKOUT(1K5)
1PF
PAINT SCHEME - 0 6
1SA
PACKAGE-OPTION 01 (1SA)
1T1
HOSE,RADIATOR & HEATER,SILICONE RUBBER SE0 SILICONE RUBBER HOSE(1T1)
1Z2
Unk.
14E
TRIM COMBINATION- CLOTH, LT GRAY (14E)
14I
INTERIOR TRIM LT GRAY (14I)
41Q
MOLDING COLOR,BLACK (41Q)
6A2
STEERING COLUMN,SEO KEYED SEO KEYED STRG COL(6A2)
6A4
KEY,SINGLE KEY SYSTEM FOR ALL LOCKS,NO SPECIAL CODE SINGLE KEY SYS(6A4)
6H7
LOCK CONTROL RR CMPT - AUTOMATIC TRUNK, RELEASE, LH
6SB
COMPONENT-COMPUTER SELECTED,SUSPENSION SUSP(6SB)
6Y5
ORNAMENTATION - EXTR, EMBLEM, NON-INSTALLED
7B3
SPECIAL HANDLING SUSPENSION SEO SUSP(7B3)
7L9
COOLING SYSTEM - STEERING, OIL
7P8
COOLER,ENGINE OIL AUXILIARY SEO AUX ENG OIL CLR(7P8)
7SC
COMPONENT- COMPUTER SELECTED, SUSPENSION SUSP(7SC)
7Z5
FUSE BOX,ADDITIONAL 12 VOLT SEO ADDITIONAL 12V FUSE BOX(7Z5)
8HJ
COMPONENT- RR LH COMPUTER SEL SUSP (8HJ) SUSP(8HJ)
9C1
POLICE CAR SEO POLICE CAR(9C1)
9HJ
COMPONENT- RR RH COMPUTER SEL SUSP (9HJ) SUSP(9HJ)
AAT
PAINT PROCESS - TWO TONE SPECIAL
AA7
WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7)
AK5
RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
ARL
PLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL)
AS7
SEAT,55-45 FRONT SPLIT FRT SPLIT ST(AS7)
A75
SPRING,SEAT FRONT,CUSHION AND BACK,HEAVY DUTY HVY DUTY FRT ST(A75)
A76
SPRING,SEAT REAR,CUSHION AND BACK,HEAVY DUTY HVY DUTY RR ST(A76)
C60
AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DG8
MIRROR,BREAKAWAY,FEATURES FOLD & PARK ACCOMMODATION(PAINTED) O/S LH REM CONT,RH DIRECT CONT MIRROR PAINTED(DG8)
MIRROR,O/S LH REM CONT RH DIRECT CONT,FOLDING,PAINTED O/S LH REM CTL,RH DIRECT CTL FLDG,PA(DG8)
DL5
DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
EGW
FLEET PROGRAM - DELAYED WARNING
FE9
FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FLT
SALES PROCESSING - OPTION
GU4
AXLE,REAR,3.08 RATIO 3.08R(GU4)
IHE
TRIM - INTERIOR DESIGN (HE)
JA9
BRAKE HEAVY WEIGHT, DISC/DISC BRAKE,HD DISC/DISC(JA9)
JL9
BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
KD1
COOLING SYSTEM,TRANSMISSION OIL TRANS OIL CLG(KD1)
KG9
GENERATOR,140 AMPERE 140 AMP(KG9)
K34
CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
LT1
ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
MX0
TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
M30
TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NA5
EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
N10
EXHAUST SYSTEM,DUAL D/EXH(N10)
N30
STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30)
N40
STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
N81
TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81)
TIRE,SPARE(FULL SIZE RADIAL)(EXPORT) FULL SIZE RADIAL SPA(N81)(EXPORT)
N92
COVER WHEEL,BOLT ON COVER WHEEL,BOLT ON(N92)
N97
WHEELS,15X7,HEAVY DUTY HVY DUTY WHL(N97)
P2B
PRICING TWO COLOR, CLASS A (B/F/W-TRK CKGMST) CLASS "A" TWO COLOR PRICING(P2B)
QQG
TIRE ALL- P235/70R15/N BL R/PE ST TL AL3 107V TIRE(QQG)
R4Y
TIRE BRAND ALL - GOODYEAR
R6D
CONTROL - SALES ITEM NO. 04
R7A
CONTROL - SALES ITEM NO. 26
R8S
CONTROL - SALES ITEM NO. 68
R9W
CONTROL - SALES ITEM NO. 97
Mr pogo is offline
post #26 of 40 (permalink) Old 11-29-2012, 05:29 AM Thread Starter
Damn. That's some good info man thx. So my car his 87,000 miles on it?!?!?! It read 67k on it now.
showtime is offline
post #27 of 40 (permalink) Old 11-29-2012, 05:32 AM Thread Starter
Oops read it wrong. 87,150 in the database
showtime is offline
post #28 of 40 (permalink) Old 11-29-2012, 06:51 AM
Nothing wrong with a Caprice clone, but if you knew that before hand. My main issue would be with the guy that told you it was an Impala and then lafter the sale says it is a clone...that's a bunch of BS. It is a shame that you did not get what you thought or were told it was.
Certain clues I see in the pics show me it was not an impala. Things missing like twilight sentinel, yellow trunk button on HL switch, other interior stuff. But on the plus side, they did a good job on the exterior and adding impala trim.
Overall, looks like a good start and a nice ride that can be modded as you like. I added eibach pro springs to my 95 caprice years ago and love the look and ride. I could add a few pics if you want to get an idea on stance. A good set of shocks would complete tHe package. Just chalk up the false Impala billing as a learning experience and see what kind of honor this seller has when confronted with what you know NOW.
post #29 of 40 (permalink) Old 11-29-2012, 07:17 AM Thread Starter
oh pretty good advice.....the car wasn't really a bad buy..i just wish i could have done more research cuz i trusted his word but u live and learn...if i decide to keep car i'm goin to put some money in it to make it my own....ur caprice on photo gallery or at ur garage???
showtime is offline
post #30 of 40 (permalink) Old 11-29-2012, 07:34 AM
Photo gallery...no. In my Garage....yes
But here is a link with.some pics of my car, kind of before and after. See post 2 of this thread.
how much did you pay for your Bbody and post a pic
I've added a lot to her over the years so can appreciate having a bone stock Caprice with little options.
