How to Remove Varnish Deposits from a Carb? - Chevy Impala SS Forum
post #1 of 18 (permalink) Old 01-02-2011, 05:00 PM Thread Starter
Erik's Avatar
I have to rebuild the carburetor for my snow blower and it has a fair amount of what looks like varnish buildup in the bowl and on the float. What's the best way to clean it up? Regular old carb cleaner? Something else? Thanks.
Nodding Tiger Mod
http://www.impalassforum.com/vBulletin/image.php?type=sigpic&userid=15034&dateline=1214775786
Erik is offline
post #2 of 18 (permalink) Old 01-02-2011, 05:19 PM
JZ9C1LT1's Avatar
Brake cleaner is good. Gasoline or Acetone is also good.
96 9C1 LT1 with all the bolt on crap (Gone 1/08 to 9C1 heaven aka junkyard!)
95 9C1 LT1 New toy as of 6/09 (this one is now heading same direction as the 96)
95 9C1 LT1 The new black mariah! SOLD
95 9C1 LT1 Will be my 13/14 winter project
04 GTO SOLD
Originally Posted by BewbZowt(+ Y +)
Here's how it works: If I can see them, they are real.
JZ9C1LT1 is offline
post #3 of 18 (permalink) Old 01-02-2011, 05:25 PM
LTwon's Avatar
Hmmmm tough question!
May your worse day of 2016 be equal to your best day of 2015.
LTwon is offline
post #4 of 18 (permalink) Old 01-02-2011, 05:42 PM
Mr pogo's Avatar
for varnish you want a dip type carb cleaner you can soak the parts in, not the spray stuff.
http://berrymanproducts.com/Products...sCleaners.aspx
Mr pogo is offline
post #5 of 18 (permalink) Old 01-02-2011, 06:25 PM
Heavy_SS's Avatar
Yep, this is the stuff my buddy uses for gummed up carbs when he buys a used motorcycle, typically the carbs are all 'effed up.
Originally Posted by Buford T. JuSStice View Post
Nobody is born into the Fat, Wise-Arse sitting in a paid house with a Camaro outside... you have to work for that.
Originally Posted by Big Kahuna View Post
Yolo!
Eric
'96 BBB-WX3 w/52k
Cam, heads, gears, exhaust!
Heavy_SS is offline
post #6 of 18 (permalink) Old 01-02-2011, 07:33 PM
SixSpd95's Avatar
Gasoline works great since it's usaully handy. The other stuff I am sure works well, but I never have any around. Cut a plasic coffee can or a gallon jug in half and let the parts sit for about 30 minutes and then just get a stainless or brass brush and finally just use compressed air to get the parts dry.
Norm Anderson
1996 DGGM......all stock, but back in the game!!
1996 BBHP#2/383.....SOLD!!
1994 DGGM Woody wagon.....mostly stock.....SOLD!!
1968 Impala Sport Coupe.....383/700R4.....SOLD!!
1995 DCM BBHP #97.....SOLD!!
1995 LAB Caprice wagon.....SOLD!!
SixSpd95 is offline
post #7 of 18 (permalink) Old 01-02-2011, 08:40 PM
Rocko350's Avatar
Definitely buy a new needle and seat. If the carb is varnished, disassemble it before dipping it in cleaner. The needle and seat will have some wear and will make the carb flood the engine if reused. Make sure not to submerge anything that isn't metal. Including the float.
Chris
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
Rocko350 is offline
post #8 of 18 (permalink) Old 01-02-2011, 09:10 PM Thread Starter
Erik's Avatar
Thanks. I have a rebuild kit that includes new needle, seat, welch plugs and various gaskets and seals, so that should be good. I may try the gasoline first since I have that, and see what happens. Thanks for the tip on the Berrymans product too.
The float looks to be brass. Why not submerge it?
Nodding Tiger Mod
Erik is offline
post #9 of 18 (permalink) Old 01-03-2011, 01:15 AM
BewbZowt ( + Y + )'s Avatar
Soak it in Pine-Sol.
Midwives help people out.
BewbZowt ( + Y + ) is offline
post #10 of 18 (permalink) Old 01-03-2011, 04:48 AM
wood95sslr's Avatar
Ditto what Pogo said Erik, get a gallon of carb dip. [I couldn't locate my gallon can for the product brand - it's outdoors in the petroleum locker in a freezing shed. Hotlanta NOT right now].
It won't hurt the brass seat or other brass parts; put them in a very small tin can and submerge it too - overnight for all.
Squeaky clean when done and can be douched with water to neutralize. Then hit everything with compressed air; parts and passages.
With carb clean, strain the carb dip to remove any carb crap and return it to its can for future use. Lasts long time in sealed container.
dw
wood95sslr is offline
