2014 Corvette Motor is an LT1 - Chevy Impala SS Forum
post #1 of 38 (permalink) Old 10-24-2012, 11:36 AM Thread Starter
Barbarossa's Avatar
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
a new LT1...
The next generation Corvette engine is the Gen V LT1
M Gen 5 Small Block launch
http://ls1tech.com/forums/automotive...o-release.html
Quotes:
"Swapped intake and exhaust"
"One VERY big intake and one modestly sized exhaust valve"
"Twisted shaped high-flowing intake and exhaust ports"
"Centralized spark plug"
“Buried the pump and injectors in the valley to reduce 'click' from the DI system at idle.”
“Deck height is the same, rod length, stroke and bore are the same. Crank to cam centerline are the same."
"We hope it is very difficult to crack the computer code." (Eeep!)
"There will still be LS crate and service engines being built. No more further LS engine development."
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
Barbarossa is offline
post #2 of 38 (permalink) Old 10-24-2012, 11:56 AM
chydog's SS's Avatar
Move over LS swaps
The LT1 is back in business - so what's a crate LT1 gonna cost us
96BBB 63K PCM4Less, 3.73 K&N FIPK, Delete\'s,stealth bolt Bilsteins Alpine HU RF 6 channel/Image Dynamics,Kaotic upper/lower CA,. Racetronix FP, garys headlight harness,
2010 GMC Crewbab - Storm Grey stock, Line-X
LT1 stroker - Forged Compstar 383 supplied by Ellwein, AI 200 cc competition heads, GMPP 846 cam, CIA tri-y's, OBD I conversion tuned by alex
http://www.cardomain.com/ride/241521...evrolet-impala
chydog's SS is offline
post #3 of 38 (permalink) Old 10-24-2012, 12:05 PM
Signature Section Moderator & CrossFire Club Ambassador of Kwan
Cracka Ass Crackuh's Avatar
Does that mean the value of my wagon just tripled?
Cracka Ass Crackuh is offline
post #4 of 38 (permalink) Old 10-24-2012, 12:42 PM
Darigaaz's Avatar
no optispark?
04 Silver Birch Mercury Marauder 4.6
95 BBB Chevy Impala SS 5.7 LT1
Darigaaz is offline
post #5 of 38 (permalink) Old 10-24-2012, 12:46 PM
Brent C.'s Avatar
Suhweeet!!
2008 DTS
Brent C. is offline
post #6 of 38 (permalink) Old 10-24-2012, 01:11 PM
95 imp's Avatar
Location: Benson AZ.- U.S. of A.- where fast cars are non existant too!
Send a message via AIM to 95 imp
65 volt di controller?
2k+ injector pressure....
computer code very difficult to crack....
imma seeing BIG $$$ to mod this motor.
95 DGGM- in 2010 shape
94 capiece 9c1- 396- still doing the mathmatics here.
http://www.pcmforless.com
the ONLY man you need for your pcm.
welcome to the b-body tavern, where whoop ass is on tap and drinks are on me.
95 imp is offline
post #7 of 38 (permalink) Old 10-24-2012, 03:56 PM
B. Campbell's Avatar
Send a message via AIM to B. Campbell
2nd Corinthians 4:16-5:8
B. Campbell is offline
post #8 of 38 (permalink) Old 10-24-2012, 04:02 PM
Send a message via AIM to illmatic96ss
illmatic96ss is offline
post #9 of 38 (permalink) Old 10-24-2012, 07:39 PM
Ultimate Impala Guru!
AutocroSSer's Avatar
I'm not . None of those are exactly new (or "uncracked") technologies...and that is far from the first time I've heard that about an ECU.
Ed Runnion -- San Jose CA -- edrunnion73@gmail.com
96 BBB, Red Bowtie Mod...that's my story and I'm sticking to it!
ROD SCCA ISSCA HAIL NASSA FASST
2006 GMC Sierra 2500 HD, Duramax/Allison, a little better than GM made it
2012 Hyundai Genesis Coupe R-Spec, 3.8L V6, Daily Driver and Autocross Toy (yes, it's RWD)
AutocroSSer is offline
post #10 of 38 (permalink) Old 10-24-2012, 10:50 PM
95 imp's Avatar
no. the bosch/dmax set up is similar in pressure. DI is fairly new, and you probably need 65v to run the heavy coils in the injectors.
the point is a 2k+ pump that can flow enough for 1k hp isn't gonna be cheap.
smaller injectors can be used due to the pressure. but they have to handle the pressure too.
rebuilt d-max injectors are 150 + 87. for the nozzle. each.
there aren't gonna be any rebuilt injectors for a 1k hp motor around for quite a while (if ever).
few people will be able to crack the code. that means the price will be high for programming.
everything else will probably be similar pricing. (VCT, heads, cranks, etc)
95 imp is offline
