Female Needs a little help 96 b-body impala ss fuel problems? - Page 2 - Chevy Impala SS Forum
post #11 of 91 (permalink) Old 01-17-2013, 12:24 PM Thread Starter
Originally Posted by Got 'Cupcake' Bearings? View Post
+1 Unless you like to hang out with all the leg humpers in MISK
Thanks for advice I have moved to appropriate thread.
HeatherBelle is offline
post #12 of 91 (permalink) Old 01-17-2013, 12:25 PM
Needles.Kain's Avatar
Who doesn't?
Build a man a fire and he's warm for a day, set that man on fire and he's warm for life.
Needles.Kain is offline
post #13 of 91 (permalink) Old 01-17-2013, 12:28 PM
Oh, and Heather dear, I suggest you add the other pertinent information you've already revealed here to that new thread.
post #14 of 91 (permalink) Old 01-17-2013, 12:30 PM Thread Starter
Thanks Dear.
post #15 of 91 (permalink) Old 01-17-2013, 12:35 PM
wytltng's Avatar
Just because you don't hear the pump doesn't mean the pump is bad.
I have never heard my fuel pump run in any GM cars that I have owned unless it was on its way out. My 94 Fleetwood i cannot hear the pump. My 91 that has a different pump than stock to run 65 PSI, i cannot hear. My 1995 K2500 Suburban had 300K on original fuel pump I could not hear the pump run. If the pump is noisy than it is bad. These cars came from the factory without noisy pumps.
Stop passing on inaccurate info.
wytltng is offline
post #16 of 91 (permalink) Old 01-17-2013, 12:37 PM Thread Starter
I wasn't aware I was passing on inaccurate info. You cannot hear it if your sitting in the car. If your near tank you hear something when key is turned on.
post #17 of 91 (permalink) Old 01-17-2013, 12:39 PM
Got 'Cupcake' Bearings?'s Avatar
Originally Posted by HeatherBelle View Post
Ok so car would run a little shoddy when cold then one day it started popping, backfiring and farting. Then wouldn't start.
To me, the above would point to the opti. I've seen my fair share of popping and farting and it always pointed to the opti, especially on a 96.
95 Impala SS-SOLD!!
2009 CTS-V
6 speed
Luxury Land Yacht
_________________
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
George Carlin - 1937-2008
Got 'Cupcake' Bearings? is offline
post #18 of 91 (permalink) Old 01-17-2013, 12:40 PM
angelo's Avatar
2 points
the original pump is "quite" but i could hear mine if i listened for it.
when it died the replacement was WAY louder and can hear it no problem when i turn the key.
so i think you are both right...
-ALF out....
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #19 of 91 (permalink) Old 01-17-2013, 12:42 PM
They can't both be right, I propose Thunderdome!!!
post #20 of 91 (permalink) Old 01-17-2013, 12:47 PM
angelo's Avatar
are you implying heather looks like Tina Turner ??
-ALF out...
angelo is offline
