Female Needs a little help 96 b-body impala ss fuel problems? - Chevy Impala SS Forum
post #1 of 91 (permalink) Old 01-17-2013, 11:49 AM Thread Starter
Red face Female Needs a little help 96 b-body impala ss fuel problems?
Ok so car would run a little shoddy when cold then one day it started popping, backfiring and farting. Then wouldn't start. Listened for fuel pump to prime and nothing, so sensible decision, replaced fuel pump. Car still won't run. It will kick over and run for like 3 seconds. Won't prime, it's like no power to pump. Any suggestions
HeatherBelle is offline
post #2 of 91 (permalink) Old 01-17-2013, 12:28 PM
wytltng's Avatar
need to check fuel pressure & check for spark while cranking.
wytltng is offline
post #3 of 91 (permalink) Old 01-17-2013, 12:29 PM
Needles.Kain's Avatar
Female or not, these guys are gay.
Build a man a fire and he's warm for a day, set that man on fire and he's warm for life.
Needles.Kain is offline
post #4 of 91 (permalink) Old 01-17-2013, 12:30 PM
Got 'Cupcake' Bearings?'s Avatar
And Needless would know. He's the bottom
95 Impala SS-SOLD!!
2009 CTS-V
6 speed
Luxury Land Yacht
_________________
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
George Carlin - 1937-2008
Got 'Cupcake' Bearings? is offline
post #5 of 91 (permalink) Old 01-17-2013, 12:31 PM Thread Starter
Thanks for tips.
post #6 of 91 (permalink) Old 01-17-2013, 12:32 PM
Thanks for the tips.
post #7 of 91 (permalink) Old 01-17-2013, 12:45 PM
streetcar2try's Avatar
Heather. Open the hood, on the pass. side on top of the wheel well, there will be a red wire that doesn't connect to anything. Using another piece of wire, jump it to the Pos. side of the battery. You should hear the pump run. If not, then begin to troubleshoot the small things first. In the fuse box right where the wire is, swap out the fuel pump relay with another like it from inside the box. Under the lid will tell you what is what. Cheack any and all fuses that may relate to the fuel system. Don't forget the one inside your drivers door on the side of the dash.
With the relay swapped, touch off jumper again, if no pump is heard, 98% chance the pump is bad. If you do have to replace pump, BE SURE to do filter as well. It's located along the drivers side frame rail about a foot in front of the rear wheel.
In my personal dealings, You better hope it's not a Racetronix pump in there. If so, throw it as far as you can. Spend the extra $$ and get an AC Delco, it has a lifetime warranty.
94 ImpSS, Currently a 24x 383 LTx. Built by Me.
Machining by Competition Automotive & Machine
Harness by BP Automotive (Bill)
Tuning by James at Shortuning.com
Mike Harris Crossmember
much, much more....
streetcar2try is offline
post #8 of 91 (permalink) Old 01-17-2013, 12:52 PM Thread Starter
Relay and fuses have been checked. I have not done anything with that wire. The pump is not kicking on when i turn the key, would red wire have the same affect? Just replaced fuel pump. It is ac delco, ill keep in mind about racetronix. I'm kinda at a loss. Someone (not on forums) suggested crank shaft?
post #9 of 91 (permalink) Old 01-17-2013, 01:03 PM
You certain you got all the wiring correct and that the existing wiring wasn't faulty, cause it usually is crispy by the time the pump goes out? Anyway, not that I don't think you're going to get great help here in the Misk section...cause I do think that you aren't, perhaps you should post this in the Maintenance section up higher on the board where you're more likely to get help.
...and no offense to the other gentleman, but his Racetronix opinion is just that and shouldn't be taken as gospel.
post #10 of 91 (permalink) Old 01-17-2013, 01:22 PM
+1 Unless you like to hang out with all the leg humpers in MISK
95 Impala SS-SOLD!!
2009 CTS-V
6 speed
Luxury Land Yacht
_________________
