Go Back   Impala SS Forum > 91 thru 96 B-body Model Specific > Fleetwood
  #21
Old 11-04-2009, 06:10 PM
HUF's Avatar
HUF HUF is offline
HUF is on a distinguished road
Originally Posted by RE LAC SN View Post
I've had issues with mine for a while now...my fleetwood don't turn as easy as my buddies did and occasionally at a decent rate of speed (above 45) the wheel jerks. (This is mostly goin into a turn and it pulls into the turn further). Now my bearings for my pulley whine occasionally (on the to do list) and I have a very very slight power steering fluid leak, I'm talkin I filled it to the correct level about 6 months ago and its still good. Y'all think this is just my pump or maybe the power assist acting up due to a bad sensor? Where is this sensor located?? Thanks
I believe variable assist sensor is on the pump itself. Disconnecting it should result in permanent FULL assist (according to the FSM). As it was mentioned before there is another sensor on the column. Check the trouble codes. There must be PS-related ones.
The resistance in my variable assist circuit is wrong and sometimes it is hard to steer in a parking lot, but which is much worse sometimes it is too easy on a highway. I have got 128 PS-related history code all the time. Disconnecting that sensor on the pump resulted in 126 code, but it did not look like I had full assist after disconnecting it. Go figure...
  #22
Old 11-05-2009, 03:15 PM
RE LAC SN's Avatar
RE LAC SN RE LAC SN is offline
RE LAC SN is on a distinguished road
I'm gonna have to try this....now with regards to my codes...I put a roadie climate control in...can I still check my codes from this or do I need to swap the fleet one back in?
77 Chevy Caprice (In the process of a frame off-man I miss her)
80 Chevy Caprice (droppin the lt1 and 4l60e from \/ in it)
94 Fleetwood Brougham (parting out)
95 Fleetwood Brougham (my daily) K&N filter, Meziere Elec. WP
  #23
Old 11-05-2009, 05:53 PM
HUF's Avatar
HUF HUF is offline
I do not know, but it is worth to try and see.
1995 Cadillac Fleetwood Brougham 92,XXX miles.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
