bleeding cooling system - Page 2 - Chevy Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Heating/Cooling/HVAC
Old 03-01-2011, 08:41 PM
bighom20's Avatar
bighom20 bighom20 is offline
bighom20 is on a distinguished road
ok and the hose does it have to be poly?
94 Impala SS BBB-135k-Bagged on 20'' oasis-Sold
95 Impala SS DCM-Mostly Stock
ISSCA#2418
Reply With Quote Quick reply to this message
Old 03-01-2011, 08:43 PM
Nick Danger's Avatar
Nick Danger Nick Danger is offline
Nick Danger is on a distinguished road
I didn't attach the hose to the engine. I got a long enough piece to go across the fender and into the bottle. I keep it in the garage. That way, the hose can be anything.
1994 Roadmaster Wagon.
Mrs Danger's site: www.unseengallery.com
Old 03-01-2011, 08:44 PM
bighom20's Avatar
so you cant actually leave hose on? you only put hose on when its time to bleed right?
ISSCA#2418
Old 03-01-2011, 08:52 PM
96SSbbb's Avatar
96SSbbb 96SSbbb is offline
96SSbbb is an unknown quantity at this point
Either way is fine, leave it on take it off doesnt matter.
Old 03-02-2011, 12:58 AM
Gregg-O's Avatar
Gregg-O Gregg-O is offline
Gregg-O is an unknown quantity at this point
You really shouldn't have to be doing this so often that you need to leave the hose on.
Taxes are not levied for the benefit of the taxed.
\'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows.
Old 03-02-2011, 03:57 PM
AM 96SS's Avatar
AM 96SS AM 96SS is offline
AM 96SS is on a distinguished road
Originally Posted by 96SSbbb View Post
Very nice, I'm going to be doing flush and fill. I will be doing that MOD. Thanks 96SSbbb
BBB 1996 Impala SS
  • K&N FIPK
  • Flowmaster Cat-Back
  • Goodyear Hi-Miler Hose Kit
  • Black Stocker 17x8.5 255/50
Old 03-13-2011, 11:03 PM
Scuba Steve's Avatar
Scuba Steve Scuba Steve is online now
Scuba Steve
I accidentally snapped my bleeder valve off today and did this mod as a fix. Works great, thanks!
1996 Impala - 190,000 miles - 1/4 mile: 14.94
2008 Grand Marquis - 1/4 mile: 16.26
Old 03-13-2011, 11:59 PM
CRSSDCM's Avatar
CRSSDCM CRSSDCM is offline
CRSSDCM has a little shameless behaviour in the past
Originally Posted by Marky Dissod View Post
Here's my take on the 94 B-Car Field Service Manual's Draining & Refilling Procedure:
3. Open the coolant drain valve/petcock at the bottom of the driver-side radiator end tank.
Loosen and eventually disconnect the radiator outlet hose at the bottom of the passenger-side of the radiator.
One thing I would like to add here is when you drain the old coolant prior to a flush do NOT repeat do NOT looSSen the plastic petcock as they are known to like to break on the first loosen and never seal properly ever again.
Just do the lower rad hose method.
1 of the 12,180 since March 1996.
Denise Milani is the hottest female ever created and put on this planet. Case closed.
Originally Posted by Got 'Cupcake' Bearings? View Post
Sorry to break it to you but Metal is dead. The 80's ended a long time ago.
"I am Metal and I'll never die. We are Metal and we'll never die." -Ronald James Padovano
Old 03-30-2011, 07:42 PM
Marky Dissod Marky Dissod is offline
Marky Dissod is an unknown quantity at this point
Considering CRSSDMS's wise advice, I've made some important corrections to:
The 94 B-Car Field Service Manual's Draining & Refilling Procedure:
DRAIN
1. If car is hot, loosen coolant recovery reservoir cap VERY SLOWLY until a slight hiss is heard. When hissing stops, continue loosening cap VERY SLOWLY until a slight hiss is heard again. Repeat until cap is removed.
2. If car is cold, just remove the coolant recovery reservoir cap.
3. Loosen and eventually disconnect the radiator outlet hose at the bottom of the passenger-side of the radiator.
4. Do something to protect the Opti-Spark from the coolant about to issue forth from the air bleeder valve.
5. Open bleeder.
6. Remove both knock sensors on both side of the engine block.
7. Allow system to drain completely.
REFILL
8. Re-tighten radiator outlet hose.
9. Install knock sensors.
10. SLOWLY fill cooling system through the coolant recovery reservoir, just past the top of the 'FULL COLD' mark.
11. Close bleeder when bubbles disappear, and only coolant is visible.
12. Run engine till thermostat opens.
13. Reopen bleeder.
14. See Step #11.
15. Reinstall coolant recovery reservoir cap.
[16. Experience has shown that steps #11 thru #15 may bear repeating, depending on how thoroughly the system was bled.]
Haven't gotten around to getting one, but the
Enhanced Bleeder Valve
is pretty sweet.
1g1bl82p7rr127841
Rest In Pieces, In Peace
  #20
Old 08-29-2013, 06:55 PM
94SSuperSSport's Avatar
94SSuperSSport 94SSuperSSport is offline
94SSuperSSport is on a distinguished road
Quick question... Is the engine on the whole time? Just making sure it is BC I feel like I bled it right but engine was on the whole time
Insurance
Please select your insurance company (Optional)
Random Question
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
(c) 2007-2014 Impala SS Forum
