Fuel line leak - repair options - Chevy Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Engine Problems/Maintenance
Old 05-20-2011, 08:50 PM
Master slacker Master slacker is offline
Master slacker
Default Fuel line leak - repair options
The leak location is behind the driver's side door, about 18 inches downstream of the fuel filter on the supply (3/8 inch) line. It looks like it was chafed and it just wore a small hole / tear, but there is nothing in the area for it to rub as it is between two supports with nothing else around. Weird.
Anyway, seeing as complete replacement lines are no longer available, I'm looking into repair options. So far, the only good option I see is a 12 inch nylon replacement with two barbed ends:
  1. Autozone - Dorman 3/8 in. (10 mm.) x 12 in. with barbs flexible nylon fuel line repair - part number 800-181 - $11.99
  2. Napa - Contents : (1) Fuel Line
    Length : 12"
    Manufacturer : Dorman Automotive Manafacturing
    Manufacturer Part Number : 800-181
    Product Application : Universal - $5.99
There's another rub an inch away from this hole, so I'll be removing at least one inch of existing hose as it is. Every other post I've seen in my searches mentions a "Napa kit" or replacing the entire line with OEM piece. Are there any other options, opinions, or recommendations? Thanks
Kevin
96 BBB: Tri-Y's, RT cats, 160 T-stat, 1.6 RR's, LT4 KM, RAISS, TB bypass, Summit turbo mufflers/crossover, ZQ8, and Mueller bushings.
Reply With Quote Quick reply to this message
Old 05-21-2011, 12:34 AM
biohazardmind biohazardmind is offline
biohazardmind is on a distinguished road
Napa also has a kit that builds these push lock lines. You can get 90 deg or straight fittings and the tubing comes in bulk so length is up to you.
Balkamp # BK 8275112 the kit has all the PN's I am sure you can buy the pieces individually and the tool that presses the fitting into the tubing.
Old 05-21-2011, 05:06 PM
silverfox103's Avatar
silverfox103 silverfox103 is offline
silverfox103 is on a distinguished road
Send a message via AIM to silverfox103
I repaired gas lines on my good ole northeast daily driver wagon several years ago. I used the NAPA kits. They worked great. They were still good when I sold the car after two years.
Tom C.
1994 RMW LAB---my toy from FL 156,000
1994 Caprice Wagon---never seen winter 105,000
1996 Cadillac Fleetwood---never seen winter 65,000
Old 05-21-2011, 08:28 PM
Master slacker
But what is the "Napa kit"? That's what I don't understand. Is it the piece I have in the first post?
Kevin
Old 05-21-2011, 09:05 PM
CapriceLt1 CapriceLt1 is offline
CapriceLt1 is on a distinguished road
Send a message via AIM to CapriceLt1
The NAPA kit works great! its about 25$ for 2 2' lines with quick disconnects on them.
what you showed was the one line patch kit. as long as you don't need the quick disconnects you can use that. OR if you have some fuel lines laying around you can just buy the 2 gold 'barbs' or whatever you'd like to call them at the end and make 'em yourself. Just put the end of the lines in hot water for them to expand, insert the gold connector and repeat. as long as you have the 2 gold connectors at the end and a piece of line you can do it.
I had to buy the kit because my fuel filter broke off at both end of the quick disconnect which is why i paid 25$...hope it helped
'94 9C1 R.I.P
'95 9C1 "Cordelia" Dual Cone Intake, LT4 Knock Module, H pipe w/2.50" exhaust pipes and glass packs, turndowns before rear axle
'81 Chevy Stepside Pickup, (project) 350/350 Combo with 4:11's in rear
'89 Kawasaki EX500 (ninja)-I had to buy a fuel efficient vehicle 50mpg
'Cordelia'
tuner pro RT, 52mm TB, Pypes 2.5" X pipe with Flowmaster 40's and PAINT! I love to paint
Old 05-22-2011, 12:37 PM
Master slacker
So the Napa kit has quick disconnects, which I don't need. Gotcha. Thanks
Kevin
Old 08-15-2011, 03:37 PM
Master slacker
Just a follow-up to this repair. I got the repair hose from NAPA that is pictured in my first post and installed it. Pushing the brass connectors into the existing hose was a pain and took some time to completely seat it. After a few miles of driving, no leaks are present.
Kevin
Old 08-15-2011, 06:23 PM
9c1 lover's Avatar
9c1 lover 9c1 lover is offline
9c1 lover is an unknown quantity at this point
http://www.impalassforum.com/vBullet...d.php?t=263245
this will also work with fuel lines.
DO NOT USE ASPWHOLESALE FOR ALTERNATOR UPGRADES, THEY ARE THIEVES!!!!!
SOON TO BE
Insurance
Please select your insurance company (Optional)
Random Question
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
(c) 2007-2014 Impala SS Forum
