#31
Do you have the wire diagram for a 96 caprice? L99
Thanks What do you guys think about the vipor 5901 or the prestige 997? I need to upgrade my alarm.
1995 DGGM (underconstruction) 1996 BBB (R.I.P. 2001) 1996 Caprice (R.I.P. 2013) 1970 Cadillac Sedan de Ville (uc) |
#32
I've had this alarm sitting on the shelf for YEARS!
Do you have a diagram for the 96impala? I've already had to bypass my VATS so I'd like to use the remote start and all the other goodies that come with it. Included options *User-friendly 2-Way remote with the Ultimate 2-Way Security and Remote Start system! *Responder Technology: Unique LCD Interface for 2-Way communication of command confirmations and trigger events! *Confirms all commands with easy-to understand icons, plus text! *Alerts users to security system triggers by Beeping or Vibrating! *Responder alerts you when too far away to hear it. *Only available 2-Way Remotes with 66-bit Code-Hopping! *Vehicle Recovery System *Turbo timer and optional rear defroster activation output. *Parking light flash *Dedicated 1 button start *+/- Doorlock Polarity Outputs *One 4-button LCD Remote *Optional 1 way companion Remote available *5 channels *5 zones *Flashing Blue LED light *Valet switch *Domelight Supervision output ready. *Failsafe Starter kill Built in, along with Remote Start Anti-grind (active/passive). *6 Tone Revenger Siren *Remote Panic/Car Finder *Super High Frequency Receiver (SHF) *XCRS-4 relay H/D capacity satellite relay. *Automatic configuration of remote buttons. *All models are Clone-Safe Code Hopping *Diesel mode with dedicated glow plug input. *Complete engine monitoring: Voltage or Tach *Programmable run times: 12, 24 or 60 Min. (0-60 minutes with the Bitwriter tool). *Dedicated factory security control wires. *Viper GPS Tracking System: ESP serial port Viper 791XV now includes the XHF Super 2-Way Dipole Antenna with about a 1/4 mile range
. . . ====== ITSSA96 ![]() ======
http://www.cardomain.com/ride/487392/ Last edited by SS DD; 02-25-2011 at 01:42 PM. |
#33
Go here, this will get you close, this is a diagram that I drew up for people to use, it is a Viper 5901, but generally the pinouts are the same, it may help. download rev A. main difference is you have a separate relay module and the new models have the remote start relays built in to the main unit.
http://www.impalassforum.com/vBullet...09#post2449009
Mike ISSCA member # 2344 Hoosier INC Member 1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's ![]() C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual |
#34
1996 Impala SS |
#35
hey 94MI9C1 i just purchased a alarm/remote start for my 95 impala. will that diagram for the 94 caprice be the same???
ps i am alot closer than NC i am in tawas city michigan. maybe we can meet up hahaha |
#36
It should work for your 95 caprice, It worked for my 96 Impala, his diagram is very detailed.
1996 Impala SS |
#37
As stated you should be good to go, there were only slight variances in between the years, but nothing that would affect an alarm install. Sorry for the delay in replying to this, I just saw it.
