Where to add freon? - Chevy Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Heating/Cooling/HVAC
Old 07-24-2011, 01:54 PM
y-burna y-burna is offline
y-burna is on a distinguished road
Default Where to add freon?
Where exactly is the fitting on our cars do you to attach the hose to add freon ? I see two of them . I have a 96 Impala.
Reply With Quote Quick reply to this message
Old 07-24-2011, 02:02 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
if I tell you, will you promise to take it to a shop if the ac doesnt cool any better after you added freon?
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
Old 07-24-2011, 02:31 PM
Lol....my word.
Old 07-24-2011, 02:34 PM
Mr pogo's Avatar
you want to add it to the fitting on the acumalator , ac on and idling.
try not to over charge it, orifice tube systems are dependent on pressures to keep the evaporator from freezing.
Old 07-24-2011, 02:36 PM
Thanx bud.
Old 07-27-2011, 11:10 AM
grandpas wagon grandpas wagon is offline
grandpas wagon is an unknown quantity at this point
FWIW - they are different sizes - it only fits on one.
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
All my posts contain 100% recycled electrons.
Old 07-27-2011, 07:04 PM
JVL96's Avatar
JVL96 JVL96 is offline
JVL96 is on a distinguished road
I just did mine today, if you want to do it right buy a new accumulator, install it, do a vaccum check, then add the freon (the port is on the side of the accumulator that points torwards the battery.
96 BBB SS (#40,269 of 41,934) Custom Heads Up Display and T56 limp mode delete
94 SS (#240 of 6303)
86 C10 Silverado (winter beater)
Old 07-27-2011, 08:49 PM
ghetto wagon's Avatar
ghetto wagon ghetto wagon is offline
ghetto wagon is an unknown quantity at this point
If you have a small leak, Adding some R-134a is fine. It will get you by for even a few years.. If you find a spot somewhere in the system that is wet with compressor oil, You have a big leak and its best to service the system.
The Fill side (Low pressure side) is on the Accumulator or receiver drier depending what you want to call it. The High side port (Dont touch that when charging) is near the battery/ coolant tank screwed into the high side pressure line.
When the low side is around 30 PSI on a decently hot day, It should have enough R134a added.
Insurance
Please select your insurance company (Optional)
Random Question
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
(c) 2007-2014 Impala SS Forum
