Do I need to pull the pump back off? Is this the end? On the pump drive BTW
please say its ok,I don't want to pull it apart again.
1996 Caprice Classic B4U SS wheels,resonators removed,side trim removed,ecu tune,hawk pads,Goodyear hoses,A.I.R. removed...for starters.
pull it off and install the o-rings. It can be a pain but Id do it if I were you.
95 DCM Imp SS....Daily Driver 98k and counting 72 Cutty............Weekend cruiser. |
I just did a water pump replacement and it seems those o rings are very durable. whats year is your impala? I wouldnt sweat it.
Well,I think I am going to wait a.week or two as I have to tear it down again to convert to electric fans and change opti/wires,looks like all it does is keep out dirt?
Also need to decide if I want to keep the ac pump as that is squeaking now of course.
youre supposed to grease the coupler splines on reassembly and the o-rings keep the grease in and moisture out.
without the grease or in high moisture areas the coupler rusts to the splines.
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog BH tuned PCM
You do need to replace the o-rings and you should pack the shaft connector with wheel bearing grease.
Jim B. ![]() '95 9c1, pcmperformance.com 93 tune, Dynomax Ultraflo catback, K & N box filter, LT4 KM, 160 stat, 3.08 Posi. |
