p0118 and hard start with warm engine - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Heating/Cooling/HVAC
Old 03-31-2012, 12:37 PM
96louD_paC's Avatar
96louD_paC 96louD_paC is offline
96louD_paC is on a distinguished road
Default p0118 and hard start with warm engine
I have code p0118 and I already change the sensor out once. But the code came back when I cleared it. What could be wrong now?
The dash temp gauge doesn't work either.
Car starts really bad when engine is warmed up but ok on cold starts. I have already replaced it with a vette starter about a month ago. Is the code p0118 have anything do with that?
DC INC
"desert storm" 94 caprice 9c1 5.7
"louD_paC" 96 caprice 9c1 5.7
"BLACK STALLION" 96 caprice 4.3 DD
Old 03-31-2012, 02:43 PM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
PO118 is ECT high voltage,this is the "sensor" located in the water pump. The temperature "sender" is on the passenger side cylinder head,and only drives the gauge. Do not confuse "sensor" with "sender". You will get the wrong part every time. Check connectors,and wiring for damage. FSM gets real in depth,but requires a scan tool.
Old 03-31-2012, 07:03 PM
96louD_paC's Avatar
Yea I have a scan tool and know the differences in the 2.
Do the wires to the sensor usually go bad ? As far as grounding out.
As stated I replaced the sensor already. So my nxt step is the wires.
Does any one know why the rough start?
Thanks
DC INC
Old 04-01-2012, 07:11 PM
Gregg-O's Avatar
Gregg-O Gregg-O is offline
Gregg-O is an unknown quantity at this point
If the ECT sensor on the WP is shot, it is probably telling the PCM that it's 20 degree's causing the PCM to direct more fuel to the engine thinking that it needs it...kind of like an old school choke stuck closed. Check the connector for that sensor , the wires tend to crack an inch or so away from the connector.
"A true lady takes off her dignity with her clothes and does her whorish best. At other times she can be as modest and dignified as her persona requires."
\'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows.
Old 04-01-2012, 08:41 PM
96louD_paC's Avatar
thanks alot ill look at it tomorrow
DC INC
Old 12-10-2012, 05:19 PM
mikekend's Avatar
mikekend mikekend is offline
mikekend
Default Po 118
Found this thread doing a SEARCH... (who does that anymore?...lol)
Had the PO 118 on the beater ex-taxi (9C6) and checked the wiring / connector to the sensor looking for broken wires, but it turned out to be corrosion in the connector.
Sprayed it with some CRC Electro-motive spray & scrubbed it with a small wire brush.
reconnected, cleared the code & so far so good! Thanks All!
Mike Kender
`95 DCM / `94 BBB / `96 9C6 /`95 DGGM Caprice 6-Speed!
CT TRI-9 / ECIRS #111 / ISSCA
Old 02-20-2013, 04:35 PM
96claSSc's Avatar
96claSSc 96claSSc is offline
96claSSc is on a distinguished road
I'm having this same exact problem did u fix it? Please let me know how too if you did 96loud_pac
