When I was but a boy... - Page 3 - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > Forum Announcement > New Member Introductions
  #21
Old 06-11-2012, 12:26 PM
CRSSDCM's Avatar
CRSSDCM CRSSDCM is offline
CRSSDCM has a little shameless behaviour in the past
Default Congrats on the Find!
Originally Posted by TWX View Post
Got Nittos, don't remember what series. They look good. Wish I could have had BFGs, but apparently they're essentially discontinued.
No you dont, the stock BFG's may have looked great but they performed horrible, especially in the wet. The KDWS replacements were not much better. So, you did good, hopefully you got the 555's. I run the INVO's stock size and they are great.
Gave it a 40 mile round trip and it cruises really nicely. Though on really sharp freeway ramp turns it's a little more squirrelly than the other vehicles I own. I may look into the rear suspension to see if anything's worn out.
Doubt anything is worn out at your mileage. Do some reading on the "miSSing body bushings" and the "Mueller Mod" bushings (pinks and green) from GM, they are all dried up but if you look hard enough you may luck out and find a set. The stock rear lower control arms are also a weak spot on our cars and cause unwanted hop, solid aftermarket units as well as bigger/beefier sway bars change the feel of the car instantly. Also look up the ZQ8 bump stops.
I will think of more stuff, in the meantime look up the best bang for the buck mods and Qalo's handbook.
Once again....great find, much luck to you Sir.
1 of the 12,180 since March 1996.
Denise Milani is the hottest female ever created and put on this planet. Case closed.
Originally Posted by Got 'Cupcake' Bearings? View Post
Sorry to break it to you but Metal is dead. The 80's ended a long time ago.
"I am Metal and I'll never die. We are Metal and we'll never die." -Ronald James Padovano
Old 06-11-2012, 06:41 PM
NineC1's Avatar
NineC1 NineC1 is offline
NineC1 is on a distinguished road
Welcom. Great story and enjoy this site
1995 IMPALA SS.
107,000 K
  #23
Old 06-11-2012, 06:53 PM
TWX's Avatar
TWX TWX is offline
TWX is on a distinguished road
Okay, did some reading. THAT'S BIZARRE. I can actually kind of understand why one model might lack some mountings, but normally if there were a series of seven, you'd skip 2, 4, and 6, not 1, 2, and 3! Worst case, if they did it to improve the ride characteristics for the driver and front passenger, they should have not skipped more than two in a row. I could almost understand (though I disagree with) skipping one and two, but leaving out almost half, all in the front?!
I'm not going to go too crazy on this car, with the low miles and all. Most likely, if I add a hitch for our receiver-mounted bicycles carrier I'll also add airbags in the coils, even if only the manual kind. I might look at sway bar options, but mostly for corrections rather than performance.
Plus the possibility of the body mounting...
I have that Cordoba for my toy after all... *grin*
