ABS Light Randomly Comes On - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Brakes
Old 06-18-2012, 05:40 PM
Travieso's Avatar
Travieso Travieso is offline
Travieso is on a distinguished road
Default ABS Light Randomly Comes On
ABS light comes on randomly. What's the cause and the fix for this? Any ill effects if just ignored?
95 9C1, LT1, 60E, posi, 3:08's, CAI, exhaust, tint, cloth, Imp.SS grille, p.coated inserts
Old 06-18-2012, 06:28 PM
SignatureSeriesOwner's Avatar
SignatureSeriesOwner SignatureSeriesOwner is offline
SignatureSeriesOwner is on a distinguished road
Send a message via MSN to SignatureSeriesOwner
Could be a bad wheel sensor, module, etc. The usual cause is wheel sensors drifting out of spec as they age.
Because the ABS module is separate from the actual braking system, in VA, you will not fail inspection for it.
You can drive it this way with no problems, but you will not have ABS. So, if you have to stop quick, your brakes will likely lock on you.
1994 Lincoln Town Car, Signature Series, 4.6L V8, fully loaded, 150K -
1993 GMC Sierra K1500, SLE, 5.0 V8, Auto, 129K -
1993 GMC Sierra C2500, SL, 4.3L V6, 5 Spd, 255K - Sold.
1977 Lincoln Continental Town Car, 7.5L V8, Auto, 77K -Sold.
1995 Chevrolet Caprice Classic, 4.3L V8, 156K -Sold.
Old 06-18-2012, 06:46 PM
Travieso's Avatar
Yeah that's what I was afraid of is lock up. You need ABS in L.A. with all these drivers and traffic suddenly stopping on you.
Old 06-18-2012, 08:13 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
The good side of ABS is that it allows you to steer while under heavy braking, the bad side is that your braking distance is noticable longer. Maybe 20 ft. at 55 mph. Good pedal control can get you the best braking distance without lockup. My ABS has left me in the middle of an intersection. I have never gone that far without ABS (in the same car).
It could just be dirt on the tone rings in the front hubs.
1991 OCC upgraded LO5, wrapped headers, dual Flowmasters, 3.23 posi, drop spindles & springs, Stainless full moons, 255/60/15 R, 215/70/15 F, Recaros, Nardi/MOMO SW w/QR, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi
For a parts list, check Plenty of good parts
Old mechanic's saying: If it doesn't work, hit it with a hammer...if it still doesn't work, use a bigger hammer...if it breaks, it needed replaced anyway.
Old 06-19-2012, 08:51 PM
AllenIDOXLR8's Avatar
AllenIDOXLR8 AllenIDOXLR8 is offline
AllenIDOXLR8
Default Abs
Your sig says you have changed the rear gears. Did you install a new reductor for the 3.08's? If not that is at least part of your problem. A good scanner with brake codes can tell you which sensor is bad or if the box is bad. The ABS boxes seldom go bad but you could have a tiny bit of dirt in a line some where.
96BBB,ERE-383 #7 AI Heads & Cam,TKO-600, C-6 Brakes-Tuned by TAD
96 Caprice B4U Mostly stock
Old 06-19-2012, 10:02 PM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
Slightly different tire diameters will also turn on the light from time,to time. A 275/xx on the rear,and 255/xx on the front for example. I got rid of the ABS years ago,and don't miss it one bit. Car stops better/faster without it,and none of these issues again ever.
Old 06-19-2012, 10:50 PM
Fred Kiehl's Avatar
Mine came with the 3.23 gears. There is a difference between the LO3/5 cars and the LT1 cars. You tune the gears with the LT1. The LO5s have a gear set in the VSS
Old 06-20-2012, 10:38 AM
Travieso's Avatar
Thanks guys, no it has 3.08s, never changed em.
Old 06-20-2012, 12:20 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
without a abs specific scanner about the only thing is to do is ohm out the wheel sensors (the fronts especially) which usually is the cause of random abs faults.
usually the fronts develop a break in the wiring harness due to the flexing during steering.
you could disconnect each sensor harness at the connector on the frame by each wheel, connect an ohm meter and either steer the wheels back and forth or push/pull the harness while looking for the meter to OL to determine the bad sensor.
if they are all good then its abs scanner time.
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
