I'm on the fence, and looking for some input.
The way I see it I have three options.
I'm $200 into the spare block. I have a set of Stock Aluminum Heads. I have a 58mm TPIS TB I have a spare manifold I have Gen2 Tri-Y's on the way Car has 3.73's with Eaton Posi, 3200 Yank Converter, Cat Back, and RAISS CAI On my list, is to freshen the fueling system.
![]() 1996 DCM Impala SS 14.38 @ 93.48 Build Date: 1996-12-05 ISSCA # 2360 |
ERE 383 !!! All the way. Karl is the MAN!
I second the emotion!
Hil Was Here... ![]() |
Rebuilt after about 31K miles due to a blown head gasket. It's ready for delivery......NOW! You can PM me if interested. KW
1996 BBB SS, 398ci SR 1995 DCM SS, 355ci
Bear with me as it takes me a while to rationalize things. Mean no disrespect to K.E.
$6,500 is a bunch of money though. I have a local solution, and I'm wondering where the value is at. Karl's stuff is well proven, so there is a trade off having it done locally (local is unknown with LT1's, but builds lots of SBC's). I figure: Crankshaft is $1k Rods: ~ $700 Pistons: ~ $700 Rings: ~ $150 ATI SuperDamper - $390 Stef's oil pan - $400 Titan gerotor oil pump - $40 Lets call it ~$3,800 in parts. Plus machine work ($2,000 ?). You get close to that $6,500 pretty quickly. You look at what the guys with a stock bottom end are running, and I'm thinking I can move the cost of the short block down the road a few years, until I frag this motor. I'm hoping for a car that runs 11.90 - 12.20's and be on the quicker end of the (SPORTSMAN: 12.00 to 19.99) Category.
and spun them all close to 7k rpm. Some lasted longer than others. I personally don't mind swapping motors out, i can do it in a day and each time i get faster at it. My current motor is a 357 that i bought for 700, sold off extra parts to actually make money back, so it was a budget built freebie.
1995 DCM Caprice. T56/4.56. 357 Lt1, AI cammed, full bolt ons. Feels faster than it really is.
Do it right the first time. Bought a built 383 for what I could afford. Spun a rod cap bearing. Had Karl rebuild it. When Karl tore it apart he found multiple issues with the build: multiple rod cap bearings had oil starvation damage; oil pickup fell off because of weak tack weld; a rod cap bolt was cross threaded; loose timing chain and one of the lifters was stuck open. So, with doing it "cheap" I ended up spending twice as much. Think about it long and hard. Going fast is expensive. Building AND balancing your engine is not where you want to skimp. It's not just the parts but the craftsmanship that goes into the build.
ISSCA #2305 ECIRS #222 WAIL 95 9C1: 13.16 @ 103, CC 502, CPT 3, Edge 3400, 4.10 gears 96 SS: 11.74 @ 117, ERE #26 383, LE2 heads, AI 234/242, CPT 3, Yank 3600, 3.73 gears, PCM4Less. 12.28 @ 110, Golen 383, LE2 heads, Comp 503, CPT 3, Yank 3600, 3.73 gears, PCM4Less. 13.07 @ 101, Rebuilt LT1, LE2 heads, Crane 227, CPT 3, Yank 3600, 3.73 gears, PCM4Less. 14.11 @ 95, Stock LT1, Edge 3000, 3.73 gears, PCM4Less. 95 Caprice Wagon Last edited by Lance; 11-27-2012 at 03:44 PM. |
As for using junkyard short blocks until they die, that's fine and good if you have the tools, time, garage, lift and mad skliz like Ricky Nabby to do a swap in less then an hour.
I just do not have the time and logistics to invest in junkyard short blocks. Been there done that in a car port in the winter. Not hard but time consuming unless you have everything you need and a solid junkyard near your house. |
![]() One NaSSty Black a.s.s car |
