What's the widest 15" wheel/tire I can fit on my box Caprice? - Page 2 - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Wheels & Tires
Old 12-09-2011, 05:42 AM
Firewood's Avatar
Firewood Firewood is offline
Moderator
Firewood is an unknown quantity at this point
Originally Posted by Barbarossa View Post
Hello,
someone may be along that is able to answer this, but ImpalaSS Forum is mostly about 94-94 Impala SS's.
Say no to donks.
A Box is not a Donk.
_______________________________________________
Almost every wheel and tire can be answered by clicking here!
Old 12-09-2011, 06:59 AM
SuperSport's Avatar
SuperSport SuperSport is offline
SuperSport is an unknown quantity at this point
It (as well as a 6th gen) can be voted as one if it's lifted like a 4x4, sitting on 26" wheels, with a paint scheme like a rolling skittles, m&m's, Lowe's, mighty mouse or jolly rancher billboard!
On the opposite, a Box can look just as clean as a 6th Gen... if kept tastefully clean. BUT... different strokes for different folks! To each his/her own. No two people are the same.
Have a nice day!
'86 Silverado C10 --- Bolt-on 5.3L/4L65E/Wheatley Tuned... SOLD 07/31/2009
'95 Impala SS (#1,245 of 18,365) --- It's alive, but not quite complete... SLOW PROCESS!
-SuperSport-
ISSCA #2476
Old 12-09-2011, 07:05 PM
loweredd's Avatar
loweredd loweredd is offline
loweredd
285/40/18 on an 18x10" with a 5.5" backspace, and it tucks.
79 Impala 4dr - Undergoing LS1/4L60E + Turbo swap - Airride - Steel Wheels
85 Caprice Classic - LT1/4L60E swap - TT2s - Vogtlands
Old 03-29-2012, 09:15 AM
FinnChevy FinnChevy is offline
FinnChevy is on a distinguished road
Any pics box caprice 15x10 5,0 bs wheel and 295/50-15 tires?
Old 05-02-2012, 04:04 AM
No 295/50-15 pics?
Old 05-02-2012, 07:59 AM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
Default What's the widest 15" wheel/tire I can fit
Many confuse backspace,and offset. Offset is always referencing the wheel centerline either +,or- Backspacing is the distance from the inside bead to the mounting flange. The example given of a 15x10 with 5" backspace would have a "zero" offset. The mounting flange is in the center of the wheel. If there's a choice between slightly different backspace,go with the smaller. You will always be able to move tire/wheel out with a spacer,but you can't bring it in if it's out a little to far.
Old 05-02-2012, 11:47 AM
Hilpala SS's Avatar
Hilpala SS Hilpala SS is offline
Hilpala SS has a little shameless behaviour in the past
Send a message via AIM to Hilpala SS
Have a nice day!
False. LOL....but I get the common misconception.
Hil Was Here...
Originally Posted by ProTools4 View Post
at some point a large overlap high compression motor with long tubes is going to shake & make so much sound that all metal spherical suspension noise transfer is another musician in the symphony of "Hot Muscle Cars Rule" in B minor
Old 12-01-2012, 08:53 PM
Shttn89 Shttn89 is offline
Shttn89 is on a distinguished road
does anybody know if a 28/10.5.15 would fit on stock 9c1 wheels and fit on the car without rubbing or will they be to big??My car is a 89 caprice
Old 12-03-2012, 08:36 PM
akio akio is offline
akio is on a distinguished road
Don't you mean "go with the larger" backspacing?
  #20
Old 12-03-2012, 09:02 PM
1slow96's Avatar
Default What's the widest 15" wheel/tire I can fit on my boxy
The greater the backspacing,the further in the tire/rim will be. As I mentioned before,the tire/wheel can be moved out with spacers. Most steel wheels are neutral,or close to it. I did fit a 275/60 on a 15x10,and I suspect a 295/50 would have fit also. Long story short, I meant greater. This is one reason I dislike using backspacing figures,I find offset specs much easier to use.
