I've ran Kumo's, Nitto's, Hankook's and BFG's, all have sucked in my opinion with the hankooks being the best. Serenity's are a damn good tire, i would be willing to pay $300 a tire for them.
#12
Someone asked about the 275-40-17 on a stock SS wheel. Here's a couple pic's. Tires are Nexen n7000. Inexpensive tire that handles great, quiet, and has lasted long!!
Get some rub on passenger side when car is loaded (people, stuff, etc). I'm lowered 1.5" in front & at least 2" out back.
96 Caprice Wagon: LT1, Black exterior with ruby red inside, Corvette dress, LT4 valve covers, Edelbrock headers, SRI cai, Magnaflow muffs, Dynomax stainless tips that exit behind wheels, H-Pipe, built tranny with Corvette servos, Hipro valve body & stall convertor, 9C1 rear disc w/ SS backing plates & e-brake that works, Wildwood 1.5" rotors w/ 4 piston calipers in front, swaybars front & rear, Metco rear links, 17" chrome impy wheels. 1 of 485 built!!
Too bad,you dislike BFG. The KDW is a superb tire.
Hell.....stock tires have been known to rub on some B-bodies. The Kumho ASX's (255/50-17) are less than the tires that you're looking at (about 140 ea.)......even accounting for your employee discount. And I gotta tell ya......damn good tire! http://www.tirerack.com/tires/TireSe...50&diameter=17 But for my money.....I'd go with the 285/40-17's on stock rims. They look way batter than 275/40's, and yes....they WILL fit the stock rims just fine! At least the Kumhos did .http://www.tirerack.com/tires/TireSe...40&diameter=17 Good luck! KW
1996 BBB SS, 398ci SR 1995 DCM SS, 355ci
1Slow96, are you stock height? Mine is stock height, i'm not sure if the 275/40's will look funky
No,mine is not at "true" stock height. Between the weight that's been removed from the nose,and the air-lift bags inside the rear coils. I doubt it's down much,probably less than an inch. That being said,if you're showing much of a gap it will grow slightly with these tires. The improved handling alone is a good enough reason to get them. If later on you decide to lower the car slightly,it's pretty easy done.
I am running 235/55-17 on mine. They are about the same height but an inch narrower than stock. Wasn't my first choice but the were free hardly used police takeoffs. I got 2 sets of them, so I figured I have a couple summers of burning before I got to actually pony up some cash for the right size tires.
94 Caprice Classic LS LT1 w/84k miles Transgo HD2 Shiftkit, SS Wheels, grill and spoiler, 92' Tails, Custom High Flow Intake, Dropped 2 1/2", Air Pump Delete, Resonators Deleted, BBK Shortys, flowmasters, 3.42 gears, blue LED gauges |
I know this is an absolutely horribly pic and you can't tell anything, but the impala has 245 50's up front, 275 50's in the rear. Doesn't look bad at all actually, but the fronts lowered an inch i believe.
![]() My dad bought the 245 50's in GA, where you work?
1995 DCM Caprice. T56/4.56. 357 Lt1, AI cammed, full bolt ons. Feels faster than it really is.
