Does not start - starter problem - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Old 01-16-2013, 04:41 PM
dogma dogma is offline
dogma
Default Does not start - starter problem
It makes the noise but engine does not turn over.
For the last few days, something made grinding noise, as if the starter would not disengage from the engine and would start after 2-3 tries. Now it's spinning without starting.
I thought it was the battery, put one in, to no avail.
Have the starter come apart, or stripped the teeth.
1996 Buick Roadmaster Grand Sport wagon
LT1, Comp Cam, Comp Cams Pro Mag Full Rockers 1.6, custom headers, Bee Hive valve springs, LT4 valve covers, 3.73 Motive gears, Eaton Posi, 2400 stall, Front F-Body sway bar, Rear Hotchkis sway bar, Moog 5552 springs, Monroe HD shocks, 9C1 gear box, Z28 cluster, high-output alternator, 160F Thermostat, Bonnies, PCMForLess 93 Octane tune.
Old 01-16-2013, 07:23 PM
DougDePew DougDePew is offline
DougDePew is on a distinguished road
Starter could have many things wrong with it, also there's the chance that your flexplate has some missing teeth and you're now right there with the starter.
Lift the car, crawl under, remove dust cover, evaluate.
Old 01-16-2013, 09:56 PM
dogma
What's the next thing to do, remove the starter.
Old 01-18-2013, 09:05 AM
M0U35Y's_SS M0U35Y's_SS is offline
M0U35Y's_SS is on a distinguished road
starter may no be engaging fully. i think that would be the solenoid? anyway id put a mirror under the car so you can see the starter and flywheel and have a buddy crank while you observe.
96 impala ss
dd
137xxx and counting
home plate delete
all led interior/exterior, dakota digital fan relay thingy.
door trigger radio do dad, r1 concepts rotors, monroe sensatrack shocks all around.
euro smokes on the front alteza smokes on the rear.
ddm tuning hi/lo 5k H.ID.
garys cables with a duralast red top.
recent tune up at about 130k
the more things change the more they stay the same
Old 01-18-2013, 12:19 PM
dogma
I recently had my tranny replaced, could this have anything to do with it.
Old 01-18-2013, 01:52 PM
cletus284 cletus284 is online now
cletus284 is an unknown quantity at this point
Get under your car and take a look. Could be a loose wire. Maybe they didn't torque the bolts down properly and they loosened. Could be that the starter is just going out.
2005 Pontiac GTO
Old 01-18-2013, 02:03 PM
dogma
I will do that and report.
