Idle settings for mild cam - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > PCM Programming/Engine Management
Old 07-03-2012, 06:36 PM
halfazn's Avatar
halfazn halfazn is offline
halfazn is on a distinguished road
Default Idle settings for mild cam
For a 118 / 224 with 112 lsa I have idle set to 650 on drive, I like the sound. My question is what/ how far apart do I set my park idle. Is there a range as a rule of thumb that drive versus park should be set? Temp v.s. Rpm of course!
95 Impala SS, CC502, 1.5 roller rockers, Eaton 3.73 posi, full bolt ons, Solomon tune. A/C Delete, Air Pump delete, EGR Delete, 2400 TCC, MSD OPTI and IC, 22/24 Irocs; 255/30/22-275/25/24 +13 off set, MPG LOLbc
Old 07-03-2012, 07:20 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is an unknown quantity at this point
If the idle is stable in gear, set rpm high enough that it charges properly when loaded with a/c in park, but low enough that the transmission doesn't clunk when dropped into gear.
Rule of thumb is the lowest, leanest idle, stable idle is the most efficient. You can have a bigger spread between the two tables with a car that has a stall converter. The OE calibration idles in between 30 and 35 kpa. the lower the number the more vacuum, therefore the most efficiant. Dont crank timing into it to get it to idle there either. Its better to have a low timing, lean idle.
Chris
Originally Posted by Erik View Post
My first advice to you is to edit that and call me from a payphone.
Originally Posted by Goldmaster View Post
I really can't say for sure. Once the roofies kicked in she seemed calm and easy going.
Old 07-03-2012, 07:44 PM
halfazn's Avatar
Thanks, good advice. Why do i have an ocasional small audible pop comming from my exhaust from a stop during load up? I cleaned MAF, replaced tps, cables, plugs, tightened exhaust leaks, checked iac. Is this vacuum? Or too much timing, or spring binding in my head?
Old 07-03-2012, 07:48 PM
halfazn's Avatar
I changed the fuel filter too. I am going to by a fuel pressure guage. I feel this is a lean condition from starving my injectors. I cant spin my wheels from a dead stop any more., and i have well worth more than needed in mods to make this possible.
Old 07-03-2012, 08:09 PM
Rocko350's Avatar
I think your thinking right about the issue. If you don't find an issue with fuel delivery, plan on the fuel pump wiring upgrade anyway. It helps the pump to live longer, and it will perform better too. with a modified engine we have a narrower range for "pass/fail". 38 or 39 with regulator hooked up at idle and a snap throttle jump to 45/47 is good. If it still pops and fuel pressure stays steady, we have a spark jumping issue.
Pull plug wires and put a pencil eraser sized amount of di-electric grease inside each plug end.
Chris
