Go Back   Impala SS Forum > 91-96 Impala/B-body > Electrical
Old 11-03-2009, 03:18 PM
PRican25 PRican25 is offline
PRican25
Send a message via AIM to PRican25
Default Weird problems with right side headlight/turn signal
Hi,
I'm having a weird problem that started when I noticed that the right headlight came on really dim and on my cluster the right turn signal is solid along with shows high beam faintly. While it is like this I can't use the right turn signal but the right turn signal works fine when the lights are off or when switched to "turn signal lights only" (can't think of the proper term for that mode). Thinking it was the right headlight going bad, I replaced it but still does the same thing and checking the right turn bulb (in the headlight assembly) I can see it is on but very dim and replacing that bulb gives me the same results.
Any ideas on what can cause this?
94' Impala SS
Foucuztech TRI-Y headers, Pypes X-Pipe, Dynomax Ultra Flo SS Mufflers
Old 11-03-2009, 03:40 PM
GoldSSWagon's Avatar
GoldSSWagon GoldSSWagon is offline
GoldSSWagon
Start with checking the ground next to the battery on the inner fender for corrision or tightness
Old 11-03-2009, 05:28 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Your description leads me to a hot wire problem on that light, not the ground. The blinker is solid because the circuit is not drawing enough current. Since it works when the headlights are off, it is not the ground. You could have a corroded connector, or a malfunctioning switch.
1991 Olds CC 3.23 posi, dropped, Stainless full moons, 255/60/15 R, 215/70/15 F, Recaros, Personal 13.5 inch/MOMO 14 inch SW w/quick release.
1992 Olds CC stock. 85~86K
Check my parts for sale Hand picked parts for the descriminating member. Buying non working Caprice/wagon pwr antennas w/good mast.
Old mechanic's saying: If it does not work, hit it with a hammer...if it still does not work, use a bigger hammer...if it breaks, it needed replaced anyway.
Old 11-05-2009, 08:32 AM
PRican25
Well now it seems to go off and on even with the headlights being off at rare moments so would it be the dimmer switch causing this?
94' Impala SS
Old 11-05-2009, 05:01 PM
Fred Kiehl's Avatar
If it was the dimmer, both lights would act the same. It is not a global problem. The turn signal would not act up if it was the dimmer.
Old 11-05-2009, 05:09 PM
Fred Kiehl's Avatar
A further thought, is that there may be a ground fault somewhere else on the car, that is causing another circuit to find a ground through the lights on that side of the car. My brother had a faulty engine ground...When he turned the switch to start, the headlights would come on dim. Check the engine grounds.
Old 11-05-2009, 08:35 PM
Zebrafive Zebrafive is offline
Zebrafive
Gotta be a bad ground.
96 DCM 1st Mod. 12way Bonneville seats, MOMO shift knob,Gentex Homelink comp/temp mirror,more to come!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
