Had a great day w/ 30+ B bodz showing from DC, VA, MD, DE, NJ, & PA.
DC inc hosted and was most gracious with about 15 cars, Philly inc was in the hizzy w/ around 10 cars.
John's lite weight rocket Frankenheinkle B body aka Drag Cat w/o:
No hood
Plexiglass rear door windows
Gutted and pinned on rear trunk lid
Gutted interior, no dash pad (just wires)
All doors hollowed out (no door bars, window motors nor, latches)
No inner fenders (engine fuse box relocated to under dash)
Front fender inner structure gutted
Bumper supports removed
Front sway bar deleted
Power Steering GONE
No AC
No idler pulley
No Accessory bracket
Alternator only
battery in trunk
S10 manual steering box
FlowTech Afterburner headers
2.5" flowmaster muffs
Iron head 350 LT3 w/ 502 cam
ATI 4500 stall w/ turbo 400
4.56 gears w/ Eaton Posi
12.5 x 28 ET Streets on laced Caprice alum wheels
Couldn't weigh car b/c scales were not turned on.
Estimated 3100 w/ driver.
12.78 @ 110 first pass w/ no burnout (2.30 60')as driver got flustered w/ seatbelt and forgot
We figured it would be dang close to an 11.90 w/ a 1.55 60'.
Next, we stripped out the interior wiring harness that ran under power seats
and to the doors for windows and such that are now permanently afixed (5 lbs)
Then ran 12.08 @ 110 on 2nd pass w/ 1.68 60' Spun-2 Rotations and slicks caught.
Should be hitting 1.5x 60' on a prepped track.
Next, removed lower rocker panels on exterior of doors and interior plastic trim panels
on bottom of door sills.
3rd pass ran 12.16 @ 110 w/ 1.65 60' (slightly better traction and maybe 1.5 rotation spin).
Last Pass only netted 12.94 @ 103 and later discovered a burnt plug wire on #5.
Next on the list: Install 5.38 gears, forgot to remove DS air bag,
need tubular trans crossmember, 3 gallon fuel cell under hood,
remove factory gas tank.
We will get an 11 !!!
Nab
