The leak location is behind the driver's side door, about 18 inches downstream of the fuel filter on the supply (3/8 inch) line. It looks like it was chafed and it just wore a small hole / tear, but there is nothing in the area for it to rub as it is between two supports with nothing else around. Weird.
Anyway, seeing as complete replacement lines are no longer available, I'm looking into repair options. So far, the only good option I see is a 12 inch nylon replacement with two barbed ends:
There's another rub an inch away from this hole, so I'll be removing at least one inch of existing hose as it is. Every other post I've seen in my searches mentions a "Napa kit" or replacing the entire line with OEM piece. Are there any other options, opinions, or recommendations? Thanks
