Hey guys,
I took my 94 9C1 to the shop for the transmission guy to do what I didn't have time to. I recently did a trans swap for an early 95 (worked in a 94 Caprice), and did the valve body stake. The guy replaced the internal harness, the VSS, and tested all solenoids. All work. He won't do electrical work, so I'm stuck with fixing this. I just tested pin E on the connector and I'm getting 12 volts, so it should be working, but isn't. Where do I go from here? The old trans worked fine before it finished burning up from having 175,000 on it. If it was the computer or the wiring harness, why did this work absolutely fine with the old trans?
