#1
Program Info for Automatic Climate Control
Readout Settings - -06 tach -08 coolant temp (°F) -14 speed (MPH) -24 coolant temp (°C) Instructions for putting ACC in diagnostic mode - - turn ignition to ON position (or start vehicle) - press and hold the temp up and OFF buttons at the same time until the unit does a full segment check. - Release the buttons. - Display should read -00... you are now in diagnostic mode - Using the fan up/down buttons, select desired function from above - press middle Have fun! __________________ Mike LRRS (LongRoof Rehabilitation and Retirement Services) Mid-Atlantic Division ISSCA #193, WAIL Mike's Garage http://www.reteaparty.com/
__________________
Cali-SS |
| Sponsored Links | ||
Advertisement | ||
#2
The climate control actually has even more data available than the items shown.
I keep a printout in the glovebox. It was VERY useful having the speedometer function when calibrating my new speedometer
__________________
-Stewart 1994 Buick Roadmaster Gran Sport ![]() http://www.cardomain.com/ride/732699 ![]() "None of you understand. I'm not locked up in here with you. You're locked up in here with me!" -Rorschach |
#3
i can only recover this also :
I've wanted to get a list together to see all of the ones we know/figured out Here are the ones I know of: -02 HVAC Trouble Codes -05 Program # -06 Tachometer (RPMs / 100) -07 Commanded Blower Speed (0-128) -08 Coolant Temp (°F) -14 Vehicle Speed (MPH) -15 Temp Cal Offset -18 Sun Load Sensor -20 Current Temp Valve Position -22 Temp Valve Position @ Cold -23 Temp Valve Position @ Hot -24 Coolant Temp (°C) -25 Commanded Temp Valve Position -27 Air Delivery Mode -28 Inside Air Temp (0-255 where 128=75°F) -31 Outside Air Temp (0-255 where 128=49°F) -37 EEPROM Revision # Now some of these require special proceedures to adjust, so if you mess them up, don't whine to me. You should be able to view them, but don't experiment with pushing other buttons on the CC as some of them have other functions. If anyone else knows any more, please add a post and I will add them to the list for reference.
__________________
Cali-SS |
#4
i cant get anything deeper then the 1st page.
__________________
Cali-SS |
#5
Well it use to be old news before the crash, I guess whats old is really new now.
#6
From our sticky at buickforums.com.....
Did you know that you can access your Engine(and other) trouble codes thru the Climate Control? Did you also know that you can accurately monitor the engine RPM, vehicle speed, coolant temp, and others? If so, good job! If not, look at this! ![]() This is for 94-96's!! *Please note, some of this was info copied directly from ISSF. Instructions for putting ACC in diagnostic mode - - turn ignition to ON position (or start vehicle) - press and hold the "temp up" and "OFF" buttons at the same time until the unit does a full segment check. - Release the buttons. - Display should read -00... you are now in diagnostic mode - Using the fan up/down buttons, select desired function from above - press the "middle" Button. It should be in the top right corner on the CC. - To Exit the trouble code area, and go back to the -00 display, hit the "Middle" button again. Have fun! You will see -00. You can change the funtion(it will say -01, -02, etc) with the fan up, and down buttons. Here is a list of what all the -00 numbers mean. Here are the most common you will need to know -00 PCM diagnostics codes -01 CCM Diagnostic trouble codes -02 HVAC Diagnostic trouble codes -03 SIR Diagnostic trouble codes -04 ABS/TC Diagnostic trouble codes -06 Engine RPM -08 Coolant Temp (°F) - Reading taken at Cylinder head sensor, typically 20* cooler than the -24 reading -14 Vehicle speed -24 Coolant Temp (°C) - Reading taken at the Water Pump sensor, This is what the PCM uses to control the fans. Diagnostic Pointers and Parameters No. Description Range Default Value Units -00 PCM System Diagnostic ............................................... -01 CCM System Diagnostic Trouble Codes ............................................... -02 ACAC (HVAC) System Diagnostic Trouble Codes ....................................... -03 SIRSystem Diagnostic Trouble Codes ................................................ -04 ABS/TC System Diagnostic Trouble Codes ............................................ -05 Program number .......................... 0-255 ....... n/a ............. Counts -07 Command Blower Motor Speed .............. 0-128 ....... n/a ............. Counts -14 Vehicle speed ........................... 0-199 ....... n/a ................ MPH -15 HVAC Learn Mode (Temp Cal) .............. -5 to +5 F .. 0 F ............ Degrees -18 Sun Load Sensor ......................... 0-255 ....... n/a ............. Counts -20 Current Temperature Valve Position ...... 0-255 ....... 240 ............. Counts -22 Temperature Valve Position (Full Cold) .. 180-250 ..... 180 ............. Counts -23 Temperature Valve Position (Full Hot) ... 5-60 ........ 60 .............. Counts -24 Engine Coolant Temperature .............. -40 to 151 .. n/a ............ Celsius -25 Command Temperature Valve Position ...... 0-255 ....... 128 ............. Counts -27 Air Delivery Mode ....................... 0-9 ......... n/a ... Code (see below) -28 Inside Air Temperature Sensor ........... 0-255 ....... n/a ............. Counts -31 Outside Air Temperature Sensor .......... 0-255 ....... n/a ............. Counts -37 EEPROM Revision Number .................. 0-0000 ...... n/a ............... Code |
#7
Here is a list of the trouble codes. These were posted for the Fleetwood, so some might be slightly different, or not apply.
PCM diagnostics codes... (-00) 11: malfunction indicator lamp (MIL) circuit 13: Bank 1 (left) heated o2 sensor (open circuit) 14: Engine coolant coolant temperature sensor (siganl voltage low, high tempurature indicated) 15: Engine coolant coolant temperature sensor (siganl voltage high, low tempurature indicated. 16: Distributor ignition system (low resolution pulse) 18: injector circuits. 21: Throttle position sensor TPS circuit (signal voltage high) 22: Throttle position sensor TPS circuit (signal voltage low) 23: Air intake temperature IAT sensor circuit (signal voltage high, low temperature indicated. 24: Vehicle speed sensor (VSS) circuit. 25: Air intake temperature IAT sensor circuit (signal voltage low, high temperature indicated 26: Evaporative emission (EVAP) canister purge solenoid circuit. 27: Exhaust gas recirculation (EGR) vaccum control signal solenoid valve circuit 28: transmission range (TR) pressure switch assembly fault 29: Secondary air injector (AIR) pump circuit. 32: Exhaust gas recirculation (EGR) 1 of 2 33: Manifold absolute Pressure (MAP) sensor circuit (signal voltage high- vacuum low) 34: Manifold absolute Pressure (MAP) sensor circuit (signal voltage low-vacuum high) 36: Distrigutor ignition system (faulty high resolution pulse or extra low resolution pulse detected.) 37: brake switch stuck on 38: brake switch stuck off 41: Ignition control (IC) circuit (open) 42: Ignition control (IC) circuit (shorted or grounded circuit) 43: Knock sensor (KS) circuit 44: Bank 1 (left) heated O2 sensor circuit (lean exhaust indicated) 45: Bank 1 (left) heated O2 sensor circuit (rich exhaust indicated) 46: PASS-key II circuit 47: Knock sensor circuit or control module missing. 48: Mass air flow (MAF) sensor circuit 50: system voltage low 51: EEPROM programming error 53: Sytem voltage high 55: Fuel lean monitor 58: Transmission fluid temp. (TFT) sensor circuit low (High temperature indicated) 59: Transmission fluid temp. (TFT) sensor circuit high (Low temperature indicated) 63: Bank 2 (right) Heated oxygen sensor(HO2S) circuit (open circuit) 64: Bank 2 (right) Heated oxygen sensor(HO2S) circuit (lean exhaust indicated) 65: Bank 2 (right) Heated oxygen sensor(HO2S) circuit (rich exhaust indicated) 66: A/C pressure refrigerant circuit (open or shorted) 67: A/C pressure refrigerant circuit (pressure sensor or A/C clutch circuit problem) 68: A/C relay circuit (shorted circuit) 69: A/C clutch circuit 70: A/C clutch relay driver circuit 72: vehicle speed sensor loss 73: Pressure control solenoind (PCS) circuit (current error) 74: Traction control system (TCS) circuit low 75: Transmission system voltage low 77: Primary cooling fan relay control circuit (not used with V08 option) 78: Secondary cooling fan relay control circuit 79: Trsnsmission fluid overtemp 81: Transmission 2-3 shift solenoid circuit 82: Transmission 1-2 shift solenoid circuit 84: Transmission 3-2 control solenoid circuit 85: Transmission TCC stuck "ON" 90: Transmission TCC solenoid circuit 95: Change oil lamp circuit 96: low oil lamp circuit 97: VSS output circuit CCM Diagnostic trouble codes (-01) 20: RAP enable circuit (circuit shorted to battery) 21: RAP enable circuit (circuit open or shorted to ground) 22: DIL enable circuit (circuit shorted to battery) 23: DIL enable circuit (circuit open or shorted to ground) 24: Curtesy output circuit (circuit shorted to battery) 25: Curtedy output circuit (circuit open or shorted to ground) 26: VES output circuit (circuit open or shorted to ground) 27: VES output circuit (circuit shorted to battery) 28: VES tracking tracking error (circuit open, shorted to ground, or shorted to battery) 30: "PASS KEY FAULT" telltale circuit (circuit shorted to battery) 31: "PASS KEY FAULT" telltale circuit (circuit open or shorted to ground) 32: Fuel enable circuit (circuit shorted to battery) 33: Fuel enable circuit (circuit open or shorted to ground) 34: Heaflamp enable circuit (circuit shorted to battery) 35: Park lamp enable circuit (circuit shorted to battery) 36: DRL enable circuit (circuit shorted to battery) 37: DRL enable circuit (circuit open or shorted to ground) 38: EEPROM calibration error 39: EEPROM calibration id error 40: Delay pot circuit (circuit shorted to ground) 41: Dealy pot circuit (circuit open or shorted to battery) 42: Key resistor circuit (circuit shorted to ground) 43: Key resistor circuit (circuit open or shorted to battery) 44: Steering wheel sensor circuit (circuit open or shorted to ground) 45: Steering wheel sensor circuit (circuit open or shorted to battery) 46: CCM internal failure 47: Canadian select input error HVAC Diagnostic trouble codes (-02) 01: Outside air tempurature sensor circuit (circuit open) 02: Outside air tempurature sensor circuit (circuit shorted) 03: In car air tempurature sensor circuit (circuit open) 04: In car air tempurature sensor circuit (circuit shorted) 05: Sun load sensor circuit (circuit open) 06: Sun load sensor circuit (circuit shorted) 10: Air mix motor circuit (circuit open) 11: Air mix motor circuit (circuit shorted) 26: Serial Data Communication (circuit shorted to battery, shorted to ground, or circuit open) 27: Invalid EEPROM detected SIR Diagnostic trouble codes (-03) 15: Passenger deployment loop resistance high 16: Passenger deployment loop resistance low 17: Passenger deployment loop open 21: Driver deployment loop resistance high 22: Driver deployment loop resistance low 24: Deployment loop voltage low 25: Deployment loop shorted to ignition 26: Driver's deployment loop open 35: ADS (auxiliary discriminating sensor) missing/shorted to ground 36: ADS closed/shorted to voltage 51: Frontal crash detected 52: Crash data area full 61: Lamp circuit failure 62: Redundant lamp circuit failure 71: Internal SDM malfuntion ABS/TC Diagnostic trouble codes (-04) 21: RF wheel speed sensor circuit malfunction 23: RF wheel speed sensor circuit continuity malfunction 25: LF wheel speed sensor circuit malfunction 27: LF wheel speed sensor circuit continuity malfunction 28: Wheel speed sensor circuit frequency malfunction 31: RR wheel speed sensor circuit malfunction 33: RR wheel speed sensor circuit continuity malfunction 35: LR wheel speed sensor circuit malfunction 37: LR wheel speed sensor circuit continuity malfunction 41: Right front valve soleniod malfunction 42: RH outlet valve solenoid malfunction 45: Left front valve solenoid malfunction 46: LF outlet valve solenoid malfunction 47: ASV prime line solenoid malfunction 48: USV pilot valve solenoid malfunction 51: Right rear valve solenoid malfunction 52: RR outlet valve solenoid malfunction 55: Left rear valve solenoid malfunction 56: LR outlet valve solenoid malfunction 57: TCC disable relay output malfunction 58: EBTCM internal adjuster assembly malfunction 61: Pump motor or pump motor relay malfunction 62: Traction disable switch used or RPM signal malfunction 63: valve solenoid relay malfunction 64: Throttle position signal malfunction 65: Adjuster assembly circuit malfunction 66: Adjuster assembly control malfunction 67: Throttle position sensor comparison malfunction 71: EBTCM internal malfunction 72: Serial data link malfunction 73: Spark retard monitoring malfunction 85: Low voltage. |
#8
Can anyone confirm that you can pull diagnostic codes from the HVAC on a 96 RMS? I know it works on 94/95 cars, but I just picked up my first 96 and it's got some issues.
http://www.impalassforum.com/vBullet...d.php?t=253993 It has a check engine light on, but I haven't been able to get a code to display on the HVAC... I don't trust driving it to the parts store yet to use their scanner... |
#9
This is all that I have Goldy from Alldata, it may help but not sure.
Diagnostic Trouble Codes can be accessed thru the H-AC Control Panel. CURRENT AND HISTORY DIAGNOSTIC TROUBLE CODES If the ACAC system detects an error within the HVAC system, a current and history diagnostic trouble code (DTC) will be set. Once the failure is no longer detected, the DTC will be stored only as history trouble code. A two-digit code is a current DTC and the same two-digit code preceded by a "1" is a history DTC. History codes will be stored for 199 ignition cycles. When the counter gets to 199, all history trouble codes will be cleared and the counter will be set back to zero. There will not be any indication to the operator that a failure has been detected or that a current or history trouble code is stored in the H-A/C control memory unless the self-diagnostic mode is entered. If an HVAC DTC is set, the H-A/C control will use a "default value" until the DTC has been cleared or repaired. TO ENTER THE "ACAC DIAGNOSTIC SYSTEM CHECK" To enter the "ACAC Diagnostic System Check," press the "TEMP" up switch and the "OFF" switch on the control panel at the same time. Upon entry, a segment check will be performed and then the graphic display will show pointer number "-00". If the compressor clutch is being requested, the "EXT TEMP" graphics will be displayed. The fan up and fan down switch can be used to increase and decrease the pointer number. The "MIDDLE" switch can be used to change from pointer number -02 to DTC or parameter values for pointers "05-31." TO DISPLAY HVAC DTCs To display HVAC DTCs. select pointer number "-02". and press the "MIDDLE" switch. At this time any current and history trouble codes will be displayed. A failure indicates that the control has detected an open, short to ground or faulty component in that circuit. While that failure is detected, the control will use a default value. When the graphic display is displaying numbers 200 to 299, they appear as numbers 100 through 199 with a "-" in front of them. For example. the value of 200 would be displayed as "-100." CLEARING DIAGNOSTIC TROUBLE CODES HVAC DTCs can he cleared from H-A/C control by pressing the "OFF" button while in diagnostic pointer number "-02" while the HVAC DTCs are displaying. To exit the self-diagnostic mode, press the AUTO" switch.
__________________
Mike ISSCA member # 2344 Hoosier INC Member 1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's ![]() C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual |
#10
Thanks Mike, but that doesn't help any. You get an A for effort though
The first selection in diagnostic mode (-00)is supposed to be for PCM codes. But when I hit the "middle" button, all I get is - - So I don't know that the HVAC system will pull OBD 2 codes or not.I'm pretty sure I know why the CEL is on, but would like to see what all is stored. Guess I'll have to borrow a scanner from a guy at work. It also flashes from time to time while the engine is running, so I assume that is PO300 random multiple misfire (which it definitely has lol) Has 170K and the wires look original, I wouldn't doubt if the plugs are too. But opti and waterpump have been replace before with what looks like el cheapo stuff. So I'm gonna do plugs, wires, opti, wp, seals and fix the heater core and see what happens... Still gotta go through and check the fuel pressure and stuff first, but I'm pretty confident it's in the ignition system.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
