#1
Anybody want want to walk me through on installing a starter that requires shims? I tried searching for delco starter but couldn't find one for a reasonable price. I got a good deal on a starter from db electrical but it requires shims. The last starter I bought didn't come with shims and I ended up chipping the teeth on the starter. Any input would help alot. Thanks.
#2
You need the little metal dowel that comes in the shim pack to check the clearance between the starter and the flexplate.
__________________
1995 Impala 6 SSpeed, 18" Anteras, 275/295 MXs, Euro smoothie, AS&M headers, 4.10s 1994 Caprice Wagon V92, G67, G80 ... on SS wheels 1992 Roadmaster Wagon (special radar-absorbing wood panelling) 1981 Cadillac Fleetwood Brougham D'Elegance coupe 1971 Pontiac Parisienne 17" Weld billets, shaved, bagged 1965 Impala convertible- stock Cali black plate car, 327 4bbl, maroon over black |
#3
which motor is this for?
__________________
Matt Hoffman ![]() Exhaust Video Burnout!! New Quick Video! ET: 13.5272 @99.33mph 1.82 60' ^^ Gone 7/12/09, but not forgotten
#4
95 Caprice lt1. Please explain more about starter clearence. Can I take my old starter and make sure that starter gears line up?
#5
there is no shimming. Go to autozone, buy a 95 corvette starter. Should be $120.00 Go home and remove your old starter. You'll have to pull some slack out of the power wire, but bolt up the vette starter as it comes out of the box, and call it a day. Hook up power wires of course. Take back core the next day, and be happy. I've never seen an LT1 needing to be shimmed.
__________________
#6
got a plain pos from autozone= much shimming
__________________
"Come with uncle, and hear all proper. Hear angel trumpets and devil trombone. You are invited." |
#7
__________________
grandpas wagon 1994 RMW 62K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoRam Atlanta headlights. |
#8
Also, does the car need to be jacked up very high to remove and replace the starter? |
#9
He's telling you to take the core back the next day [after installing the new one] so hopefully they don't realize you're returning a non Corvette core.
I for one think this practice is theft and so will the law if you're caught. I got a high torque racing starter from DB Electrical [smaller body otherwise as original] for under $60 shipped and its great. I used the one factory shim and the clearance is perfect. |
#10
car needs to be jacked up high on one side both dont need to come off the ground , also if you get your starter rebuilt like i did, $35 it will save you a pretty penny
__________________
ALL RWD,4 B BODIES!!! 1995 white 9c1 4 sets of rims, muffler delete 4-20-09,hollowed cats, touchscreen, kicker cvx 15 2000 watt rms DD 1991 CAPRICe CLASSIC 1st B Body all original 350 tbi over 200,000 custom 20's sold it in like '06 and hate myself for it!!! 1991 caprice w 305 around 160,000 paid $600 sold for $1200 1976 datsun 620 truck Proud owner of a RARE 1965 oldsmobile starfire 425 big block, also B BODY 400+- horse MY LT1 EATER http://www.cardomain.com/ride/2417157 R.I.P. DAVID SSON22'S |
| Thread Tools | |
| Display Modes | |
