Fuel pump problems/replacement - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 08-30-2009, 01:35 PM
SweetRide SweetRide is offline
Junior Member
SweetRide is on a distinguished road
Default Fuel pump problems/replacement
I think my fuel pump is going out. Yesterday I had fuel pressure of 0 and my car wouldn't start. I tried another time or two and saw that the pressure gauge went up to 16. I was then able to start it and the pressure went up to 34. Is this my fuel pump failing or could it possibly be something else? If I need to replace the fuel pump then what is recommended? Is the Airtex Master fuel pump from AutoZone OK, or should I get something else?
Thanks for any help.
(I have a 1996 Impala SS with 60,000+ miles)
Old 08-30-2009, 02:39 PM
Gregg-O's Avatar
Gregg-O Gregg-O is offline
Gregg-O is an unknown quantity at this point
Default
Mine did the same thing a few months ago. No problem since I did the pump. might be the filter, but I doubt it if you saw zero pressure. I used the Airtex, haven't had a problem yet.
__________________
"A true lady takes off her dignity with her clothes and does her whorish best. At other times she can be as modest and dignified as her persona requires."
\'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows.
  #3
Old 08-30-2009, 02:43 PM
rfraboni rfraboni is offline
rfraboni is on a distinguished road
Default
When my wagon did something similar issue, it also burned up, I really mean the plastic was black and melted, the connection where the pump connects to the sender. The old pump started drawing too much and was creating to much heat.
I took no chances and ended up replacing the sender as well. I used a pump advanced auto parts, nothing special just a replacement pump, and it has worked well .
__________________
94 RMW - Nothing special yet.
  #4
Old 08-30-2009, 04:12 PM
Junior Member
Default
Thanks for the replies. On the NAPA web site it recommended to also replace the wiring harness. Is this also a good idea?
__________________
1996 DCM Impala SS
Mostly stock with over 60,000 miles
  #5
Old 08-30-2009, 04:34 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
need to replace the sock for warranty coverage on the pump, the replacement wiring harness is smaller gauge than the original so idk.
I replaced my fuel pump in june with a delphi from napa but soldered/cleaned the harness terminals and reused it.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #6
Old 08-30-2009, 05:49 PM
Dan Fahey's Avatar
Dan Fahey Dan Fahey is offline
Dan Fahey is an unknown quantity at this point
Default Lesson Learned about High Volumn Fuel Pump
Add a Walbo High olumn Fuel Pump.
Works great except that the Stock Fuel Pressure Regulator will fail.
AND with interesting results.
My Fuel System would shut down after 2 hours of cruising.
Resort to bucking and backfiring.
Then the Engine Light would go on and the engine smooth out.
Then go out and start bucking and cycle back to Closed loop.
Today I replaced the stock Fuel Pressure Regulator with a Adjustable version with a Pressure Dial.
Like the Fuel Pressure test of a few days before.
The Fuel Pressure was registering 70psi.
The engine scan showed the Right Bank O2 sensor showing lean.
The injectors on that side of the engine shut down.
AT any rate that is my report
Dan
Lowered the pressure to 39psi and the car began to adjust.
Took a few miles to get the car to idle smooth.
__________________
  #7
Old 09-04-2009, 10:34 PM
Junior Member
Default fuel pump changing tips
Does anybody have any tips or advice for changing the fuel pump? Do I need any special tools or just get the tank as empty as possible and get to work? I've changed oil but that's about it so any advice/tips would be appreciated.
__________________
1996 DCM Impala SS
  #8
Old 09-04-2009, 10:41 PM
Junior Member
Default
I forgot to say that I have the new fuel pump, fuel pump strainer, wiring harness, and fuel filter.
__________________
1996 DCM Impala SS
  #9
Old 09-04-2009, 11:03 PM
5-mileBalla 5-mileBalla is offline
5-mileBalla is an unknown quantity at this point
Default
You'll need the line disconnect tools. I'll have to give you the name and such whenever I get back home.
Haborfrieght has them though.
Depending on how much gas you have in the tank you'll need to siphon. Tipping the tank and letting it drain out won't work so if you don't want a mouth/face full of gas like I had have someone that can do this or a siphon pump which is only a siphon hose with a little hand pump on the end.
Changinger the filter is easy. Its on the driver side along the frame. I can't remember where but its along the frame so look and feel for that big coke can filter.
Gotta take the exhaust heat sheilds off then the straps. I recommend having someone helping you out when you drop the tank though!
I just did this and the airtex works great!
OH YEA TEST THE PUMP BEFORE YOU PUT EVERYTHING BACK BECAUSE TAKING EVERYTHING DOWN AGAIN JUST TO SEE WHAT'S WRONG IS SOMETHING THAT WILL PISS YOU OFF! JUST LISTEN FOR THE SOUND OF THE PUMP PRIMING AND THEM BAM THERE YOU GO.
__________________
95' RMS.....blown engine mod
  #10
Old 09-05-2009, 01:17 AM
tI2ouI3LeSoIVIe's Avatar
tI2ouI3LeSoIVIe tI2ouI3LeSoIVIe is offline
tI2ouI3LeSoIVIe is on a distinguished road
Default Walbro Pump
Walbro Pump is what I replaced mine with, I researched for a while and kept coming back to the Walbro Hi-Flow and I've never had a problem without changing my fuel pressure regulator. Happy with it, just be careful and take it to a good shop, they can break the sending unit in your fuel tank if they're not careful and that'll cost a pretty penny to replace. If you're doing it yourself, the sending unit is the mechanism in the fuel tank that tells your gas gauge how much is left, GM uses pathetically thin plastic and it breaks VERY EASY.
__________________
---Brandon
1996 DGGM Impala SS
20" Foose Lusso
255/35/R20 BFG KDW2
Hotchkis Performance X-Tend TVS Package
MOOG'd Front End
3.73 w/ Strange Axles and Eaton Rear End
The Rest is a Secret........
Forum Jump
(c) 2007-2011 Impala SS Forum
