95wagon LS7 project - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Complete Car Builds
Thread Tools Display Modes
  #1
Old 09-02-2009, 03:25 PM
draginwagin draginwagin is offline
draginwagin
Default 95wagon LS7 project
Before the forum crash, Gerry was talkin' about dropping an LS7 in his spotless wagon.
Anyone else here itchin' for a project update???
__________________
1995 civie DCM Caprice wagon, Imp SS grill, 1LE PVC & swiss, Bilsteins, fbody front bar, Quickor rear bar, UMI lwr rr cntl arms, Silla AL dual core rad, mech fan del, Air Lift bags. PCMperformance tune, AIR delete, Pypes X, Frantz oil & coolant filters, added 7P8, 7Z5, 7L9
1991 OCC all stock, step daughters ride.
Weekend toy-1980 Dodge Mirada, ~ 450HP built 360 --sold
former DD-1992 1A2, L05, stock, (SOLD)
Old 09-02-2009, 10:26 PM
95wagon's Avatar
95wagon 95wagon is offline
95wagon is an unknown quantity at this point
Default
Like I originally posted the main swap would start til the fall-winter so not too much going on.
Planning and acquiring "bits " though
Covers
Collectors
Oil tank
Support Stuff
__________________
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #3
Old 12-05-2009, 07:33 PM
95wagon's Avatar
Default
Originally Posted by rh96ss View Post
Good to hear your getting your mock-up block.
Yes without your and Rich's huge help getting it from one corner of the continent to the other I would have been SOL. Thanks again to the both of you.
Gerry
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #4
Old 01-10-2010, 10:55 PM
95wagon's Avatar
Default
Mock up block and pan are finally in my possession so maybe this show can get on the road!!
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #5
Old 01-11-2010, 04:54 PM
95wagon's Avatar
Default
Originally Posted by Cmdr. Flash Gumby View Post
You never answered the question someone asked on those too-sexy collectors. Are they Vette bits or "Custom Work by Gerry"?
They are Burns
http://www.burnsstainless.com/mergecollectors.aspx
While I do my best, they are well above my skill level
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #6
Old 12-13-2010, 12:51 AM
95wagon's Avatar
Default
Why yes, yes I have
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #7
Old 12-19-2010, 12:45 AM
95wagon's Avatar
Default
While I had planed to cut the crossmember to clear the dry sump pan , it was so close to fitting (engine would sit on mounts with only a relief for the tank drain) I decided to rework the oil pan.
Clearancing, as expected put holes in the corners
Which have to be made to "go away" along with the tank drain.
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #8
Old 12-19-2010, 01:09 AM
95wagon's Avatar
Default
While the oil passages and lines may make sense in a Corvette, the routing does not if you are running the dry sump tank in the front.
To that end, I am blocking off the internal passages from pump side of pan.
The boss sitting on top will become the relocated dry sump drain (LS7 has two drains)
Machined plug intersects oil passage to "turn it off"
Lines will now come straight off pump at front of engine.
This will remove about 3 feet and numerous bends from each of the lines.
That's all for today.
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #9
Old 12-20-2010, 10:26 PM
95wagon's Avatar
Default
Chasing some pin holes but getting there .
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #10
Old 12-25-2010, 04:31 PM
95wagon's Avatar
Default
More upgrades.
Brand new SSR T56 thanks to Santa Harper
Large output, one piece counter shaft
Now the Lt1-T56 combo coming out can stay as a complete setup for some other car
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
