Impala SS Forum
Go Back   Impala SS Forum > 91-96 Impala/B-body > Engine Problems/Maintenance
Register FAQDonate Members List Calendar vBClassifiedGooglemap ME Search Today's Posts Mark Forums Read
Thread Tools Display Modes
  #1
Old 10-17-2009, 12:08 PM
tdogzjoint's Avatar
tdogzjoint tdogzjoint is offline
tdogzjoint is on a distinguished road
Default 95 9C1 LT1 injector issues...
Hey all, my '95 is having intermittent injector failure. I diagnosed this by using the stethoscope/screwdriver trick to listen, the car still has the original opti/plugs/wires and has 120k on the clock.
When I wiggle the wires for the number 7 injector, it either solves the problem or makes it come back, my question is this: Is there any other things besides bad wiring that would cause the #7 injector to not fire? By the way, #7 ohms out @12.8, the manual says 11.2-12.4, is being higher better or worse?
Thanks guys,
Tony
  #2
Old 10-17-2009, 02:35 PM
tdogzjoint's Avatar
Default
On a side note, is there any way to check reference voltage from the PCM to the injectors? And if so, what value would I look for?
  #3
Old 10-17-2009, 03:54 PM
Buffman's Avatar
Buffman Buffman is offline
Moderator
Buffman is an unknown quantity at this point
Send a message via AIM to Buffman
Default
if you wiggle the wire and it goes away/comes back, then injector wiring harness clip is bad. replace and see if problem persists.
__________________
Matt Hoffman
Exhaust Video Burnout!! New Quick Video!
ET: 13.5272 @99.33mph 1.82 60'
^^ Gone 7/12/09, but not forgotten
  #4
Old 10-17-2009, 04:13 PM
tdogzjoint's Avatar
Default
By clip do you mean the connector that goes on top of the injector itself? Thanks.
  #5
Old 10-17-2009, 09:12 PM
kpeters59 kpeters59 is offline
kpeters59 is on a distinguished road
Default
Th clips on the injectors are known to develop a 'yawn'.
Pinching them cured a flashing MIL on my car.
-KP
  #6
Old 10-18-2009, 10:05 AM
Buffman's Avatar
Moderator
Default
yes sir. I had a miss that went away on the number 7 cylinder. Turns out the pin on the inside of the injector connector was broken, and when it would shift certain ways it wouldn't contact. Napa has a new connector..
__________________
Matt Hoffman
  #7
Old 11-04-2009, 04:02 PM
tdogzjoint's Avatar
Default
Ok, update, got number 7 fixed and all the other injectors by bending the pins slightly on each injector top, ensuring absolute contact at all times. There is still a rolling miss, around every 10-20 engine revolutions, and doesn't seem to be a particular cylinder either. I was wiggling with wires on the coil( car off, key out)and got quite a big shock, does this mean my coil's goin' ?
I'm going to do the voltage test as mentioned in the haynes manual later today and keep it up to date,
Later,
Tony
__________________
'95 9C1 LT1
  #8
Old 11-04-2009, 10:16 PM
klEEnR.SS's Avatar
klEEnR.SS klEEnR.SS is offline
Junior Member
klEEnR.SS is on a distinguished road
Default
take the injectors to get dem cleend up and chage the fuel filter 2
  #9
Old 11-04-2009, 11:27 PM
V8killer's Avatar
V8killer V8killer is offline
V8killer is an unknown quantity at this point
Default
yes yes fuel filter has always been known to cause electrical problems ... well documented don't you know?
__________________
ISSF MEMBER #282
94 9C1,SS clone,DCM,herter pcm,SSRI,HA/F-body sway bars,3.42's Bonnies,floorshift,Stillen front bumper,billet grille,Smoothy rears ,white face Z-28 dash, Dynomax mufflers,Tri-Y,eibach,J&M control arms,NOS 100 shot,MSD digital+6&coil,MSD super conductors,metco safety loop,Dynotech driveshaft 12.98@110MPH 1.61 60' shift point and rev limiter problems
STOLEN ON JUNE 8TH OR 9TH 2003 FROM TACOMA,WA
  #10
Old 11-05-2009, 01:31 AM
tdogzjoint's Avatar
Default
Hey you got any more pics of that wagon?
__________________
'95 9C1 LT1
vB code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 2007 Impala SS Forum
