alignment specs - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Suspension
Thread Tools Display Modes
  #1
Old 10-20-2009, 01:14 PM
chevyridnhi chevyridnhi is offline
chevyridnhi is on a distinguished road
Default alignment specs
hey guys, could someone possibly post the modified alignment specs for a caprice with 20s. I remember seeing on the forum a while ago about fixing the general wandering of the car when you have 20s, but i cant find it. My 94 has brand new inner and outer tie rod ends, all other suspension is in good shape. I just did the alignment and had front toe at -.02 and +.02 with total toe at 0. i forget the caster and camber specs but they were within oe specs. The car drives straight and the steering wheel is straight but every once in a while it will wonder..either left or right. can anyone help?
Old 10-20-2009, 04:42 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
http://www.sofasst.com/tech/alignment.htm
Not sure if those are applicable to you or not. Its not really an issue with the tire size, but mods to the suspension that change ride height could make those specs difficult/impossible to achieve.
__________________
2005 Pontiac GTO
  #3
Old 10-21-2009, 06:52 AM
jloehlein jloehlein is offline
jloehlein is on a distinguished road
Default
If the car isn't pulling consistently in one direction then your alignment should be fine. Road surfaces are very rarely exactly flat, which causes cars to pull one direction or another.
If you want to learn more about what the alignment measurements actually mean, read this.
  #4
Old 10-21-2009, 07:02 AM
iLOVEmyBIGbody iLOVEmyBIGbody is offline
iLOVEmyBIGbody
Send a message via AIM to iLOVEmyBIGbody
Default
these?
__________________
  #5
Old 06-26-2010, 07:54 PM
jasonlachapelle's Avatar
jasonlachapelle jasonlachapelle is offline
jasonlachapelle is an unknown quantity at this point
Default
wrt Toe in, is it measured in degrees or inches ? The FSM has degrees, 1/16 being about .06 as specified in the FSM.
Are the modified specs 1/16" to 1/8" ANOTHER 1/16" to 1/8" ?
__________________
Jason
1996 Roadmaster Wagon
1995 Caprice Wagon
1987 Buick Regal Turbo T
1998 Buick Riviera
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
