| Register | FAQ | Donate | Members List | Calendar | vBClassified | Googlemap ME | Search | Today's Posts | Mark Forums Read |
#1
Never having had any problems with power steering, I wonder if any of you have had this. I have a '96 FWB and once in a while the PS goes out. Fluid is full. It comes back in anywhere from a few seconds to a half a minute, with no problems for maybe 2 weeks or more, then it happens again.
Any ideas would be appreciated. Thanks, Paul
__________________
'96 FWB, med. blue,.....named "Bluezer" '96 SLS, raven black,....named "Maaaa" '00 Montana, brown,.....named "Squrl" '46 Wife, white,...........named "Carolyn" |
#2
Does it happen at low speeds? Like parking lot and in the driveway? Check your water pump. It's leaking on the belt and causing it to slip. Really.
If not, not sure. Because with the variable assist, if the sensor goes wonky, it defaults to full assist. Not fun in the middle of an on ramp! Could be the pump, but usually they complain when they are dying. When was the last time the fluid was flushed? You could try pulling the fluid out of the reservoir with a turkey baster (DON'T put it back in the kitchen! Get your own at the dollah store! ) and refill it with good stuff. Run it, cycle the wheel back and forth a few times, and then do it again. That'll replace a good deal of the nasty fluid. Might help. Might not. Good luck!
__________________
Bill "The Verb" Crovo - Resident Car Slut ![]() 95 White WB4 "GS"-The Marshmallow- Forget everything you know, Something Wicked this way comes... 01 GMC 2500 ECSB SLT -The Slut- 6-OH!, four by, and loaded to the gills. So much for leaving it stock... 66 Caddy Calais -The Cadirat- 429/TH400. Baby Powder Blue with Swiss. Metallic blue cloth interior. Stay tuned. ISSCA #257 www.badassofne.net |
#3
Low speeds it is. I'll check this out.
__________________
#4
like it was mentioned before, a good flush and add some of teh lucas power steering fluid is very good, where in virginia are you located?
__________________
96 9c1 (wreck at 267.xxx, gone) 96 9c1 295/50/15 on 15-8 front n 15x10 on rear, 3.73s, sligthly modified and lot of that. 95 9c1, intake, exaust and some 95 fleet, stock but work in progress. 95 fleet, for sale 94 caprice st.wagon, 3.42s, sligthly modified and some |
#5
I've had issues with mine for a while now...my fleetwood don't turn as easy as my buddies did and occasionally at a decent rate of speed (above 45) the wheel jerks. (This is mostly goin into a turn and it pulls into the turn further). Now my bearings for my pulley whine occasionally (on the to do list) and I have a very very slight power steering fluid leak, I'm talkin I filled it to the correct level about 6 months ago and its still good. Y'all think this is just my pump or maybe the power assist acting up due to a bad sensor? Where is this sensor located?? Thanks
__________________
77 Chevy Caprice (In the process of a frame off-man I miss her) 80 Chevy Caprice (droppin the lt1 and 4l60e from \/ in it) 94 Fleetwood Brougham (parting out) 95 Fleetwood Brougham (my daily) K&N filter, Meziere Elec. WP |
#6
It's the water pump. Watch it drip, drip on the belt.
I'm in Waynesboro, Va. Paul
__________________
#7
The sensor is on the steering column, right near the firewall, engine side. The connector is on the bottom of this, and I believe it has 4 wires. It wasn't too hard to unplug it, but from what I've read, it takes hours to remove and replace the sensor. Mine will not be connected again. .
__________________
. ![]() ^ ^ ^ ^ ^ AL GORE HATES ME!!! ^ ^ ^ ^ ^ |
#8
The resistance in my variable assist circuit is wrong and sometimes it is hard to steer in a parking lot, but which is much worse sometimes it is too easy on a highway. I have got 128 PS-related history code all the time. Disconnecting that sensor on the pump resulted in 126 code, but it did not look like I had full assist after disconnecting it. Go figure... Last edited by HUF : 11-04-2009 at 06:17 PM. |
#9
i have had lucas kill 3 pumps i will never use that ish EVER again
#10
The 95 is OBD I and Green antifreeze.
The 96 is OBD 2 and Orange antifreeze.
__________________
| Thread Tools | |
| Display Modes | |
