Why are my plugs fouling? - Page 2 - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #11
Old 10-27-2009, 04:09 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
plug wires, opti or coil may be needing replacement, a weak spark can cause plugs to foul excessively.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
Old 10-27-2009, 04:38 PM
bolivia_ss's Avatar
bolivia_ss bolivia_ss is offline
bolivia_ss is on a distinguished road
Default
Wires are brand new. But any recommendations on the other 2 parts? I don't mind spending money on my car. I love the car I just want it to run right.
  #13
Old 10-27-2009, 07:19 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
The coil is cheap, the opti is expensive...take your pick.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
  #14
Old 10-27-2009, 07:26 PM
bolivia_ss's Avatar
Default
What's expensive? I don't use the term expensive with this car until you get into the $500 and up range....
  #15
Old 10-27-2009, 08:39 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
Doing an Opti is a $400 job just in parts if you do it right. At least $260 for the Opti itself EBay - thepartsladi), $30 for the timing cover seal kit, $100 for a new water pump (it has to come off, so if its old, replace it) and $40 in antifreeze, plus $5 to make the tool to instal the oil seal out of a highlighter.
Start by doing diagnostics. Black fouled plugs are a sign of running rich. How old are your O2 sensors and is your check engine light on?
__________________
2005 Pontiac GTO
  #16
Old 10-28-2009, 10:14 AM
bolivia_ss's Avatar
Default
It's a 94' and I'm pretty sure none of that has been replaced so I don't mind doing it....
  #17
Old 10-28-2009, 10:51 AM
Dan Fahey's Avatar
Dan Fahey Dan Fahey is offline
Dan Fahey is an unknown quantity at this point
Default
Originally Posted by bolivia_ss View Post
Naw, they were black as hell...
OK.. are they all black..?
Getting oil?
Cracked rings or leaky Valve Guides will have oil residue.
Fuel Regulator - Put a guage on it, should be 40psi range.
Make sure the Coil Wire is clean
Check under hood Fuse Box
D
  #18
Old 10-28-2009, 10:55 AM
Henry '06 Henry '06 is offline
Henry '06 is on a distinguished road
Default
check the wires that go to the coil, not the plug wire but the other two. Wiggle them and make sure the wires are not loose. If you wiggle them and the car shuts off replace them. I was having issues with fouled plugs and car shut off and this was my issue.
__________________
1995 9c1 Impala Clone
  #19
Old 10-29-2009, 11:10 AM
bolivia_ss's Avatar
Default
How do I tell if I'm running rich? So is there any chance that there's something else wrong besides around the plugs, wires, or what not? Like I said I'm going to get it fixed WHATEVER it is. I don't care what it is. Just gotta find what it is first.
  #20
Old 10-29-2009, 05:49 PM
Default
You're probably going to need a laptop and cable to do some datalogging and see if anything looks wrong.
__________________
2005 Pontiac GTO
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
