#21
Damn. I wish I had the bones to do this mod. I can't seems to save much in this economy.
__________________
1995 9C1 Caprice, 318,000 miles, 2" drop, wide whites on 275/60/15, 2800 stall, bilstiens, mods, and decent flat-black paint job! http://www.cardomain.com/ride/2513883 |
#22
__________________
Stonebreaker 355 ci 11.99 at 115mph on 150 hp nitrous 2002 ECIRS CHAMPION Ph.D. in R.E. (Redneck Engineering) Aerodynamics are for people who can’t build engines. - Enzo Ferrari |
#23
Then what's the point, if the only thing your building it for is street use? I mean yea, if you HAVE TO HAVE 700rwhp then go for it...just sayin if you just want to be the baddest car on the block for stoplight encounters, save your money and realize you don't need 700rwhp.
__________________
96 BBB- never runs. Old setup LE2's/396/TH400: RIP 2006 new project: AI 200cc/396/D1SC/TH400/Gearvendors OD 94BBB SS- (Daily Driver) flowtech afterburners, 2.5" exhaust w/ summit turbos, RAISS, pcmforless.com tune, cat delete, EGR delete, AIR delete, Hotchkis springs/Bilstein shocks, PPM front end/poly bushings, Global West rear LCA's http://www.youtube.com/watch?v=3ZvPZi9fL8k <--96 old setup
#24
Think people should watch this thread carefully, lot of experienced guys on there...pro race car builders and such. Im sure a lot of good will come out of it...
http://board.moparts.org/ubbthreads/...gonew=1#UNREAD
__________________
#25
Yes, I could squeeze more power out of the D1S1 setup using the smaller pulley but 10psi at 6K rpm is plenty and perfect for what I do with the car. The more boost the more fragile the setup gets. One minor issue can get real expensive.+1 on getting power down. Cold road and cold tires = driving on ice even with 525rwhp. Also be sure to get you some real brakes. The TCE Big Brake kit is incredible. I've had people say they were more impressed with how quick the car stops than its neck snapping acceleration. Sounds crazy but better brakes allow you to go faster. Then there's springs and sway bars when straight away ends. B-Bodies are freaks around turns when you have them setup correctly. Go ask the pissed off Porsche guys ![]() I've made a lot of mods to my car over the years and have it just how I want it. Looking back, the T56 conversion is still my favorite mod. It makes the car more enjoyable to drive although it does little for the drag time slips. Now is the time if you're gonna do it. You are seeking info in the right place. Good luck with the build.
__________________
Mark S. T56/383 Stroker/ProCharger D1SC Blower Dynoed 525.6 RWHP, 516.6 RWTQ 12.881 @ 110.31 (Street Tires) VIDEO: BLOW BY at Putnum Park!! MOTOR PIC: Look under the hood 1st \'08 ISSCA Road Race [FTD] 1st \'07 ISSCA Road Race [FTD] 3rd \'06 ISSCA Road Race 3rd \'06 ISSCA Autocross 1st \'05 ISSCA Road Race [FTD] 1st Lanier Shootout - 2003/04/05 Lanier Record 16.849 Way Too many mods! Last edited by faSSt94Impala : 11-05-2009 at 08:17 PM. |
#26
As one racer put it, "I want enough power to spin the tires at the end of the straight... and then I want bigger tires!"
__________________
#27
You guys give very good opinions...eventually I am going to do an LS9/TCI 6X six-speed combo. I need to look into the functionality of the combo.
#28
Bill, you coming to SSHS9. The MISSL boys rolled into the Jameson Inn about an hour ago.. |
#29
Thanks guys that's why like this web so much info from guys that have done it befor and so many differnent ways to go about it. Keep it coming more info. Yes i will take photos of this build up when i get it started.
#30
Food for thought here..but power is useless without putting down to the pavement.
__________________
Eric Seaman 1996 DCM 383 LT1 11.91@113 1.58 60' last time out. 1996 DCM LT1 Bolt On Car 12.60@104 "retired to a 383" 1994 Caprice Wagon 15.01@ 93.56 STOCK! 2004 SSHS4 King of the Hill SEIRS 2007 Champion |
| Thread Tools | |
| Display Modes | |
