Paddle or sequential shifter for T56? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 12-03-2009, 12:46 AM
Bugman's Avatar
Bugman Bugman is offline
Bugman
Question Paddle or sequential shifter for T56?
Does anyone know where I might be able to find either a paddle or sequential shifter for the T56? I know Aston Martin used a paddle shifted T56 in the Vanquish, but I'd rather not go that route because of the cost and that the system is tied in with other sub systems. Do any of the GT/road race type race cars use them? Thanks for the info.
__________________
Disclaimer: Any hokey-assness on my personal vehicles does not reflect the quality of my work done while I'm on the clock
Old 12-03-2009, 02:52 AM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
The only thing that comes to mind is if it was an air shifter, usually paddle shifters are only related to automatics as it would be retarded in my eyes to have a paddle shift and you still have to push the clutch in. Just my two cents. Not sure if the Vanquish would use a T56, maybe 6 speed auto? I don't know. Good luck on the search, I have never heard of one.
EDIT: did a quick google search and found this
http://mastershift.com/new-street-manual.html
Also discussed here
http://wiki.ls1tech.com/forums/manua...shift-t56.html
Hope this helps.
Mike
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #3
Old 12-03-2009, 03:52 AM
StormUnit's Avatar
StormUnit StormUnit is offline
StormUnit is on a distinguished road
Send a message via AIM to StormUnit
Default
Mike
dont ferrari's have clutches with paddle shifter???? lol
__________________
My toy things:
1967 camaro-midnight blue, with 468bb heads and cam, drag radials.. searching for traction. when it had the 350sb mild build n some n20 best time 11.52@120mph
1994 9c1-white, 355ci, hooker exhuast, 52mm tb, scorpian rollers and springs, trans -4l60e went boom- Zo6 wheels.
2007 Gsxr 600- sold
2000 Hyundai station wagon- dark blue,extreamly dirty, with 83k, a broken tail light lens and missing armrest cover yepp i drive this when the caprice is broken lol
  #4
Old 12-03-2009, 05:37 AM
Mista M Mista M is online now
Mista M is on a distinguished road
Default
I remember a company that had the idea for paddle shifters, don't know what became of it. It was a wierd name like shrifter or something.
Found it...
http://twistmachine.com/shopping/ind...=index&cPath=1
__________________
95 Caprice L99
"..At the worst, if he fails, at least he fails while daring greatly.."
TEDDY ROOSEVELT
  #5
Old 12-03-2009, 08:51 AM
383LSxIMPALA's Avatar
383LSxIMPALA 383LSxIMPALA is offline
383LSxIMPALA is an unknown quantity at this point
Default
Yes but ferraris are a differant ball game.
__________________
2006 ram 2500 4x4 crew cab long bed. billet inglewood trans. s366 turbo. efi live. twin cat stacks. stock fueling 8.58@82.56 at over 8500lbs
  #6
Old 12-03-2009, 09:07 AM
94MI9C1's Avatar
Default
Very true!!
The clutchless manual that Ferrari uses also electronically changes the timing and torque curve to make the shifts possible.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
  #7
Old 12-03-2009, 09:16 AM
bammax's Avatar
bammax bammax is offline
bammax
Default
Ferrari is fair game. All cars run on the same principals just using different methods to achieve their goals.
For a true shift conversion you should look into using an electric solenoid to depress the clutch a half second before the shifter solenoid engages. That way when you hit the paddle or button or whatever you decide to use it will engage the clutch and then the shift mechanism in sequence.
I see 3 main tricks to this technique. The first trick will be delaying the shift solenoid by the right amount of time to allow for full engagement of the clutch. The second is for the clutch solenoid to release after the shift. The final issue is finding a clutch solenoid that will be strong enough without resorting to hydraulics.
I'd consult someone that knows about solenoids and maybe even someone who could make up a little digital curcuit board to control the order and timing of the solenoids.
__________________
Follow me to:
Badass of NE
ImpalaSSforum
9c1net
  #8
Old 12-03-2009, 09:22 AM
toomanytoyz's Avatar
toomanytoyz toomanytoyz is offline
toomanytoyz is an unknown quantity at this point
Send a message via AIM to toomanytoyz
Default
Am I the only one on this planet that doesn't "get" paddle shifters?
__________________
Bill "The Verb" Crovo - Resident Car Slut
95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner...
00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc...
94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said.
American Ricer
www.badassofne.net
"Ooooh! Look! Something shiny!"
LOWER IT!!!
  #9
Old 12-03-2009, 09:25 AM
UndercoverPunk UndercoverPunk is offline
UndercoverPunk is an unknown quantity at this point
Default
I thought most of the fun swapping in a t56 was rowing the boat?
  #10
Old 12-03-2009, 09:27 AM
Default
My thoughts EXACTLY!
__________________
American Ricer
www.badassofne.net
LOWER IT!!!
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
